Become a Member
Hi, I have used the Amigopod web gui to produce a CSR, and have received the .pfx file from my CA. However the web gui keeps giving me 'invalid format' error when I'm trying to import the file. Please can someone help?
Your certificate needs to be in .pem format. See if your CA and give it to you with a .pem extension.
ok, many thanks for your help
Depending on the Instant OS version you have. The latest Instant OS version do support pfx format. However, you need to make sure that the private key is exported and saved together with the public key in the pfx file.
