Comware
Problem with 3com Baseline 2928-HPWR Plus WebUI
  • 1.  Problem with 3com Baseline 2928-HPWR Plus WebUI
    Posted Jan 11, 2015 01:28 PM
    Hello!
    New to the forum, hope I can get help here.
    I recently purchased a used 3com Baseline Switch 2928-HPWR Plus 24 but upon accessing the webUI I seem to have a lot of blank unusable pages, I'm using chrome/internet explorer.
    There is only a few usable pages on the webUI, not too sure how to access via telnet/ssh, or if there's updates for the firmware/software
    Love some advise.
    P.S. This thread ahs been moved from Switches, Hubs, Modems (Legacy ITRC forum) to Comware-Based. - Hp Forum Moderator
  • 2.  RE: Problem with 3com Baseline 2928-HPWR Plus WebUI
    Posted Jan 12, 2015 09:46 AM
    I think the 3com 2900 series  resembles the HP1910 series. the
    3com 2928-HPWR specifically matches the 1910-24G-PoE (365W) Switch (JE007A).
    It should run comware 5, and you should be able to access the console configure it from there
    (enable the telnet- or ssh-server, to what fits you the best)
    below is a link to the comware release 1103 manual, not sure what release your 3com runs)
    http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c03941555-2.pdf
    Regards
