Problem with RAP
This thread has been viewed 23 times
kdisc98
kdisc98Feb 08, 2013 09:04 AM
  • 1.  Problem with RAP
    Posted Feb 08, 2013 08:04 AM
    Dear Friends,
    I am trying to configure RAP-2WG with Aruba200 controller. When i connect RAP with controller its show up but when I provision the AP to any AP Group it does not come up and shows as down.
    Details of configurations are in attached file. Please have a look into it and advice.
    Attachment(s)
    docx
    RAP Problem.docx   18 KB 1 version
  • 2.  RE: Problem with RAP
    Posted Feb 08, 2013 08:15 AM
    in your log ,i can see the following error:
    No ISAKMP PSK found for peer 192.168.2.125
    1.did u configured the right VPN settings? (that allowing u to use cert or user/password/shared)?
    2.did u whitelisted this RAP?
    3.seems like a cert\secret issue.
    Another thing,that u might wanna check: (That might sending wrong internal controller address to the rap unit)
    Do u have any LMS or BACKUPLMS configured in the AP-system-profile default? Or in the AP-system-profile that attached to any of those groups?
    It's seems that after you provision the RAP,he getting some wrong configuration (might be the LMS and BACKUP LMS - check it)
    update us if it solve your issue.
    Me.
  • 3.  RE: Problem with RAP
    Posted Feb 08, 2013 08:58 AM
    Thank You please see the response
    I think there is some problem with VPN setting but i am not able to found where the problem exist. Please do let me know what setting preview required to resolve this issue.
    Yes
    Try both certificate and PSK. Tried with different username and password and different psk as well
  • 4.  RE: Problem with RAP
    Posted Feb 08, 2013 09:01 AM
    What about the LMS / BACKLMS setting in the ap-system-profile? is there any configuration there that u did? did u checked it also?
  • 5.  RE: Problem with RAP
    Posted Feb 08, 2013 09:14 AM
    I just added LMS IP in that.. below is output for your reference
    (ICI) #show ap system-profile MyAPSysProfile
    AP system profile "MyAPSysProfile"
    Parameter Value
    LMS IP 192.168.2.222
    Backup LMS IP N/A
    LMS Preemption Disabled
    LMS Hold-down Period 600 sec
    Number of IPSEC retries 360
    LED operating mode (AP-9x/AP-10x/AP-12x/RAP-5x only) normal
    RF Band g
    Double Encrypt Disabled
    Native VLAN ID 1
    SAP MTU N/A
    Bootstrap threshold 8
    Request Retry Interval 10 sec
    Maximum Request Retries 10
    Keepalive Interval 60 sec
    Dump Server N/A
    Telnet Disabled
    SNMP sysContact N/A
    AeroScout RTLS Server N/A
    RTLS Server configuration N/A
    Remote-AP DHCP Server VLAN N/A
    Remote-AP DHCP Server Id 192.168.11.1
    Remote-AP DHCP Default Router 192.168.11.1
    Remote-AP DHCP DNS Server N/A
    Remote-AP DHCP Pool Start 192.168.11.2
    Remote-AP DHCP Pool End 192.168.11.254
    Remote-AP DHCP Pool Netmask 255.255.255.0
    Remote-AP DHCP Lease Time 0 days
    Remote-AP Backup Ports Enabled
    Remote-AP uplink total bandwidth 0 kbps
    Remote-AP bw reservation 1 N/A
    Remote-AP bw reservation 2 N/A
    Remote-AP bw reservation 3 N/A
    Heartbeat DSCP 0
    Session ACL allowall
    Corporate DNS Domain N/A
    Maintenance Mode Disabled
    WISPr Location-ID ISO Country Code N/A
    WISPr Location-ID E.164 Country Code N/A
    WISPr Location-ID E.164 Area Code N/A
    WISPr Location-ID SSID/Zone N/A
    WISPr Operator Name N/A
    WISPr Location Name N/A
    Remote-AP Local Network Access Disabled
  • 6.  RE: Problem with RAP
    Did you set the preshared key on the controller?  Did you set a username and password in the controller's local database for that AP?
    You do not need to enter the AP into the whitelist, because that is for only certificate-based APs and of course, that will not work.
  • 7.  RE: Problem with RAP
    Posted Feb 08, 2013 09:10 AM
    Hi Joseph
    YES with this command
    crypto isakmp key aruba123 address 10.10.123.0 netmask 255.255.255.0
    Yes
    I tried both i mean once with PSK and again with adding it into white list.
    Please confirm if the AP is in white list it will not get connected via PSK ?
  • 8.  RE: Problem with RAP
    Posted Feb 08, 2013 09:02 AM
    Thank You Kdisc
    Please see this
    iTt's seems that after you provision the RAP,he getting some wrong configuration (might be the LMS and BACKUP LMS - check it)
    LMS IP is correct but no LMS IP is available so not provided
  • 9.  RE: Problem with RAP
    Posted Feb 08, 2013 09:04 AM
    ok.
  • 10.  RE: Problem with RAP
    @syedmuradali wrote:
    Thank You Kdisc
    Please see this
    The LMS IP, should be blank.  The problem is that the AP does not connect via IPSEC in the first place, which has to happen even before the LMS-IP is applied.  We need to troubleshoot that portion first.
  • 11.  RE: Problem with RAP
    Posted Feb 08, 2013 09:06 AM
    But if the RAP unit if connecting to an AP-GROUP with LMS/BACKUP LMS with internal address , after the provisoning process,and the reboot the RAP will be down.
    That's the reason i told hom to check it. (and yes..on RAP groups it's should be blank)
  • 12.  RE: Problem with RAP
    Posted Feb 08, 2013 09:09 AM
    That isa  fair assessment.
    The AP must connect via IPSEC to get the LMS/Backup LMS instructions, so if the IPSEC connection is not happening, it cannot even get to that point.
    APs that have the LMS set to another controller connect via IPSEC successfully and get redirected to that blackhole, creating the "AP Down" situation.  The AP must connect via IPSEC successfully to the first controller to even get into that condition...
  • 13.  RE: Problem with RAP
    Posted Feb 08, 2013 09:16 AM
    Yep.That the reason that I thought about it(about the AP-system-profile LMS/BACKUPLMS) ...he wrote that the RAP is connecting the the Controller but going down after provising...
  • 14.  RE: Problem with RAP
    Posted Feb 08, 2013 09:15 AM
    LMS IP has been removed but still facing the same problem
  • 15.  RE: Problem with RAP
    Posted Feb 08, 2013 09:17 AM
    But in the begining you wrote:
    syedmuradali
    Problem with RAP
    Dear Friends,
  • 16.  RE: Problem with RAP
    Posted Feb 08, 2013 09:23 AM
    Hi Kdisc,
    I am sorry i dont understand what you mean to say..
    let me explain again what the problem is...
    I reset the RAP to factory default and connect it with controller its show up. but when i provision it. the rap shows down..
    This was happening when LMS IP was blank, After this i added LMS IP but problem remain the same. So now i removed the LMS as per CJoseph instructions..
  • 17.  RE: Problem with RAP
    Posted Feb 08, 2013 09:21 AM
    Okay.
    Did you put an IPSEC preshared key on the controller?:
    Did you enter a username and password into the local user database for that AP?:
    And did you provision the IPSEC key from the first step and the username and password from the second step into that into the AP?:
  • 18.  RE: Problem with RAP
    Posted Feb 08, 2013 09:30 AM
    Yes CJoseph i have performed all these steps, See the attached screeshot may be you can help me
  • 19.  RE: Problem with RAP
    Posted Feb 08, 2013 09:32 AM
    delete the IKE shared secret for 10.10.123.0
    and create a new one for 0.0.0.0 (just for the test)
    tell us it's it works.
  • 20.  RE: Problem with RAP
    Posted Feb 08, 2013 09:42 AM
    resolved... AP is showing up now....
    Thank you so much Cjoseph and Kdisc
    You are people are amazing...
  • 21.  RE: Problem with RAP
    Posted Feb 08, 2013 09:43 AM
    dont forget to KUDOS me and press on SOLVED!
    That the reason why we here. to give u some more Air into the Head :)
  • 22.  RE: Problem with RAP
    Posted Feb 08, 2013 09:48 AM
    One more question please...
    The SSID is working on "Standard" Remote AP operation.. After disconnecting from Controller how much time RAP will wait to turn the Backup SSID on ???
    Back SSID Is not working now :-(
  • 23.  RE: Problem with RAP
    Posted Feb 08, 2013 09:51 AM
    Is the SSID bridged or tunneled?  It must be bridged for backup to work.  It should come up within 30 seconds, and the AP needs to have a valid ip address (ethernet must be up, etc).
  • 24.  RE: Problem with RAP
    Posted Feb 08, 2013 10:33 AM
    When i disconnect the RAP from controller, Backup SSID start broadcasting but clients doesn't get the IP address from internaly defined DHCP server
    This is bridge
    What does it mean i dont understand
  • 25.  RE: Problem with RAP
    Posted Feb 08, 2013 10:49 AM
    After you configure a Backup SSID on the controller, you need to reprovision the AP for it to get the Backup SSID settings.  Try reprovisioning the AP with the same credentials and see if that works.
  • 26.  RE: Problem with RAP
    Posted Feb 09, 2013 02:41 AM
    1st i have create both ssid's than i provision the AP, Backup SSID is turn on when RAP get disconnected from controller, and backup SSID is also vanished when RAP reconnected with controller.
    the problem is with dhcp server configured for back ssid.. well i will further test that on monday and will get back to you...
  • 27.  RE: Problem with RAP
    Posted Feb 11, 2013 05:58 AM
    Hi Friends,
    Related to previous problem,
    Since RAP has established IPSec with Controller and working fine, when i disconnect the controller from the network, the RAP starts broadcasting the backup SSID, but when i try to connect that SSID it get connect but doesn't forward traffice.
    Problem number 2: when I reconnect the controller with network. i was expecting that the backup ssid should be hidden and Previous SSID should start broadcasting automaticaly, but its not the case, when i reconnect the controller with network the rap doesn't create IPSec tunnel with controller and keep broadcasting backup SSID..
    Please advice.
  • 28.  RE: Problem with RAP
  • 29.  RE: Problem with RAP
    Awesome.  I think Kdisc is your hero!
  • 30.  RE: Problem with RAP
    Posted Feb 08, 2013 09:24 AM
    If like you wrote -  the RAP unit is connecting to the controller and showing up in the beginning. (so the key/cert/secret/userpassword are fine)
    And then u re-provision it and it "down" forever - so it's some common config that touching all the AP-groups u trying (most likely something in the AP-system-profile)
    that's my advise as far as I was troubleshooting the problem.
    Regards.
    Me.
  • 31.  RE: Problem with RAP
    Posted Feb 08, 2013 09:29 AM
    Regards.
    Me.
    Kdisc,
    I think when Syed resets the RAP, it comes up as a campus AP, so that he can provision it, and then it disappears after he provisions it, so it never connects via IKE.  Syed, please correct me if that is wrong...
  • 32.  RE: Problem with RAP
    Posted Feb 08, 2013 09:31 AM
    yea...that what i'am starting to figure out also.
    so..i found some little advise , u gave to someone with a smilier problem:
    On the controller's commandline, type "show datapath session table | include 4500" while the RAP2WN is trying to connect to see if any traffic is being sent to the controller's ip address..
  • 33.  RE: Problem with RAP
    Posted Feb 08, 2013 09:37 AM
    The output of same command is already provided in earlier attached file. Please see below
    (ICI) #show datapath session table | include 4500
    192.168.2.222 192.168.2.125 17 4500 49235 0/0 0 0 0 1/1 1 F
    192.168.2.222 192.168.2.125 17 4500 49233 0/0 0 0 1 1/1 1b F
    192.168.2.125 192.168.2.222 17 49235 4500 0/0 0 0 0 1/1 1 FC
    192.168.2.125 192.168.2.222 17 49233 4500 0/0 0 0 1 1/1 1b FC
  • 34.  RE: Problem with RAP
    100% right
  • 35.  RE: Problem with RAP
    Posted Feb 08, 2013 09:34 AM
    found your issue:
    the error is:
    Feb 8 17:31:55 :103004:  <INFO> |ike|  No ISAKMP PSK found for peer 192.168.2.125
    and u did key for the internal vpn address 10.10.123.0
    fix it and it will work
  • 36.  RE: Problem with RAP
    @kdisc98 wrote:
    found your issue:
    the error is:
    Kdisc is correct.  Try 0.0.0.0 instead of restricting it to an ip address.
  • 37.  RE: Problem with RAP
    Posted Feb 08, 2013 09:38 AM
    If it working for u lets us know - just change the IKE Shared Secret to fit the extranlIP of the RAP unit. (and not the vpn tunnel address)
  • 38.  RE: Problem with RAP
    Cjoseph
    How you see these two outputs
    (ICI) (config) #show datapath session table 192.168.2.125 | include 4500
    192.168.2.222 192.168.2.125 17 4500 49159 0/0 0 0 2 1/1 19 F
    192.168.2.125 192.168.2.222 17 49159 4500 0/0 0 0 1 1/1 19 FC
    (ICI) (config) # show crypto isakmp sa
    % No active ISAKMP SA
  • 39.  RE: Problem with RAP
    Posted Feb 08, 2013 08:18 AM
    Are you using certificate-based RAP provisioning?  This will not work on a 200-series controller.
    Please try provisioning it using IKE preshared key and username and password provisioning...
    http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/RAP-2wg-with-800-series-controller-problem/td-p/8737
  • 40.  RE: Problem with RAP
    Posted Feb 08, 2013 09:03 AM
    HI CJoseph
    I have tried both cert and psk but its not working
  • 41.  RE: Problem with RAP
    Posted Feb 08, 2013 08:22 AM
    maybe i'm wrong but i see ipsec but no gre/papi tunnel,
     check the remote networking pdf, maybe you miss something
    http://community.arubanetworks.com/aruba/attachments/aruba/branch-wlan-and-remote-access/458/1/Aruba%20Remote%20AP%20Setup%20Guide.pdf
    read at page 13
    "Step 3: Configure the Remote AP User Role
    Once the remote AP is authenticated for the VPN and established a IPsec connection, it is assigned a role.
    This role is a temporary role assigned to the AP until it completes the bootstrap process after which it
    inherits the ap-role. The appropriate ACLs need to be enabled to permit traffic from the controller to the AP
    and back to facilitate the bootstrap process."
  • 42.  RE: Problem with RAP
    Posted Feb 08, 2013 08:30 AM
    p.s.
    i see
    maybe you miss to fix the ipsec psk password, as in previous post rap2wg user certificate with 3xx model but not with a200 model,
    here you've to use ipsec psk
  • 43.  RE: Problem with RAP
    Posted Feb 08, 2013 09:07 AM
    Hi Andrea,
    Thank you for your response,
    Following policies has been added but no success
    ip access-list session rap_policy
    any any svc-papi permit
    any any svc-l2tp permit
    any any svc-gre permit
    any any svc-esp permit
    any any svc-tftp permit
    any any svc-ftp permit
    user-role rap_role
    session-acl rap_policy
    aaa authentication vpn default-rap
    default-role rap_role
    aaa server-group RAP-Serv-Group
    auth-server internal
