Comware
Problem with the command "port group interface" to configure an IRF
  • 1.  Problem with the command "port group interface" to configure an IRF
    Posted Jul 13, 2022 01:42 PM
    Hi every one,
    I try to configure my two switchs A5120 in an IRF fabric. I have a problem with the port group interface.
    After execute those command below:
    [HP]interface GigabitEthernet 1/0/51
    [HP-GigabitEthernet1/0/51]shutdown
    [HP-GigabitEthernet1/0/51]quit
    [HP]irf-port 1/1
    [HP-irf-port1/1]port group interface GigabiEthernet 1/0/51
    % Wrong parameter found at '^' position.
    I don't manage to execute the command ?!
  • 2.  RE: Problem with the command "port group interface" to configure an IRF
    Posted Jul 14, 2022 04:53 AM
    on  Comware Software, Version 7.1.059, you can user below interfaces only
  • 3.  RE: Problem with the command "port group interface" to configure an IRF
    Posted Jul 14, 2022 05:23 AM
    Hello jcSteel31,
    I think you entered wrong(misspelled) command:
    "GigabiEthernet"
    It is missing "t" before "Ethernet" this is the reason for the error. It should be "port group interface GigabitEthernet 1/0/51"
    Hope this helps!
    -Alex-
  • 4.  RE: Problem with the command "port group interface" to configure an IRF
    Posted Jul 15, 2022 02:40 AM
    The reason is that for the 5120 only interfaces with bandwidth >= 10GB are eligible as physical interfaces within an IRF port. This applies to all comware switches as far as i know.
    Cheers
    Frank Anstoetz
    Aruba Edge Professional, HPE MASE, CCIE em. #14807
    Ingentive Networks GmbH
    Duesseldorf, Germany
  • 5.  RE: Problem with the command "port group interface" to configure an IRF
    Posted Jul 15, 2022 08:18 AM
    Ok, i dont know this particularité.So the fact that my port IS a gigabit port IS specific to my Switch or i Can increase to a Ten gigabit ?
