puedes realizar la instalacion del firwmare a traves de FTP o TFTP
Reinicia el switch y presiona Ctrl + B cuando se te indica
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Clear Super Password |
|<9> Storage Device Operation |
|<0> Reboot |
eliges la opcion
========================<Enter Ethernet SubMenu>=========================
|Note:the operating device is cfa0 |
|<1> Download Application Program To SDRAM And Run |
|<2> Update Main Application File |
|<3> Update Backup Application File |
|<4> Update Secure Application File |
|<5> Modify Ethernet Parameter |
|<0> Exit To Main Menu |
|<Ensure The Parameter Be Modified Before Downloading!> |
ingresas la opcion 5
Ingresas los datos solicitados
=========================<ETHERNET PARAMETER SET>=========================
|Note: '.' = Clear field. |
| '-' = Go to previous field. |
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :tftp
Load File Name :main.bin
Target File Name :main.bin
Server IP Address :192.168.1.1
Local IP Address :192.168.1.253
Gateway IP Address :0.0.0.0
FTP User Name :user
FTP User Password :password
luego ingresas la opcion 2
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash |
ingresas 0 para retornar a el BootWare menu
en el BootWare menu, ingresas 1 para iniciar el sistema
descargas el firmware desde aqui https://h10145.www1.hpe.com/downloads/SoftwareReleases.aspx?ProductNumber=JG923A
saludos
