Network Management
  • 1.  Problems after upgrade from E0506 to E0506P03
    Posted Oct 11, 2017 05:58 AM
    After upgrading to version E0506P03 some features of the web-interface are broken:
    - in "classic" view-mode, after clicking on the "Ressource" tab, the left-sided menu structure is incomplete andcontent is not displayed correctly (empty spaces), see picture 1.
    - displaying the "IP View" Ressource triggers an error (s. picture 2). This happens both on classic-mode and desktop-mode.
    - oh, and one hint: Do _not_ upgrade to P03 if you have a mysql 5.5 backend: The imcnetresdm process will execute a very complex SQL-Statement on the config_db database after starting up which will take forever on mysql 5.5 (and will prevent the startup of imcnetresdm). After Upgrading to mysql 5.6 this query will be executed in <1sek so everything is fine..
    best regards,
    hwuensch
  • 2.  RE: Problems after upgrade from E0506 to E0506P03
    Posted Oct 11, 2017 06:49 AM
    hwuensch,
    We just upgraded our production instance this week as well and I do not see either of these issues. I am sure you have already but I would open up a support ticket on this one. One thing I do see is that if you do a general search for a device, the result in the dynamic side bar is no longer clickable. This seems to be cross browser issue- I am not sure if the iMC team look at this forum but hopefully they do and can take a look.
    Regards
    Mike
  • 3.  RE: Problems after upgrade from E0506 to E0506P03
    Posted Oct 11, 2017 08:44 AM
    indeed,  the "general search" is also failing (it works only one time for me, after that you have to logout/login from the webinterface).
    --> we will open a ticket on this issue.
    Is anybody else experiencing these frontend errors on E0506P03? We never had such problems bevore, and this time it
    was only a minor patch-level update :-(
    hwuensch
  • 4.  RE: Problems after upgrade from E0506 to E0506P03
    Posted Oct 13, 2017 08:30 PM
    Sounds like that's my problem - i'm running MySql 55 and after the update it never finished starting 3 processes - I gave up after waiting 2 hrs and rolled it back - thx
  • 5.  RE: Problems after upgrade from E0506 to E0506P03
    Posted Nov 13, 2017 08:54 PM
    What was your process for MySql update? on Win or linux?
    If I update over the existing ImC install, dbman won't backup or restore and the update process also fails. It runs ok, but otherwise stuck.
  • 6.  RE: Problems after upgrade from E0506 to E0506P03
    Posted Nov 21, 2017 06:11 PM
    Well the update leaves a query hanging trying to update: Error Code: 1146. Table 'aclm_db.tbl_link' doesn't exist
    The query sits there waiting so a couple of processes never start. Killing the query will allow the process to start but a reboot brings it back, and it won't restore the DB anyway.
    No P03 until I talk to HP...
  • 7.  RE: Problems after upgrade from E0506 to E0506P03
    Posted Dec 12, 2017 05:03 AM
    I have the same problem after update to 7.3_E0506P03, no ip views .
    I use Microsoft SQL server 2008 R2
  • 8.  RE: Problems after upgrade from E0506 to E0506P03
    Posted Dec 12, 2017 05:22 AM
    After opening a ticket for this issue:
    In our case there was the problem of invalid network masks in 'tbl_subnet' and 'tbl_dev table' (both in databse config_db).
    For example, our database contained network mask values of 0.0.80.242 (which is not a valid netmask of course).
    You can check that by executing a sql query on the config_db database like this one:
    select * from tbl_dev where dev_ip_mask like '0.%';
    If this query lists any devices, then you should delete these devices and rediscover them.
    (You could also manipulate the wrong entries direct via sql, but beware of side-effects)
    Also check tbl_subnet for wrong entries:
    select * from tbl_subnet where subnet_mask like '0.%';
    there is a change that these or another bad entries will eventually reappear after deleting them: This issue  seems to be related with uncomplete/corrupted SNMP-queries to these devices...
    Hope this will help you...
    Helmut
  • 9.  RE: Problems after upgrade from E0506 to E0506P03
    Posted Dec 13, 2017 06:46 PM
    I did have a couple of devices with 0.0.0.0 subnet masks. And I can confirm that one of them was caused by snmp. After just basic discovery mask was correct. Then set snmp read only, it re-discovered the device but set the mask to 0.0.0.0
    No subnets with bad masks
    Fixing these did not solve my issue - have a query with a comlex join that runs forever to update a table with under 2000 rows. Stopped all the processes and ran the query directly - but killed it after 15 mins. Some other bad data...
