  • 1.  Problems with 802.1x authentication using docking stations
    Posted Oct 31, 2024 12:34 PM
    Hello everyone!
    I'm setting up 802.1x authentication using docking stations and I'm encountering this problem.
    The laptops connect with there usb c interface to the docking station and a virtual adapter with a serial number is created.
    The 802.1x authentication configuration is done on this virtual adapter and works correctly, but when the laptop is connected to a new docking station a new virtual adapter is created with a new sequence number that does not have the 802.1x authentication settings.
    The mach a ddress pass thru functionality has been activated, but this does not prevent the creation of a new virtual adapter every time a workstation is changed.
    Has anyone encountered the same problem and found a work around?
    Many tahanks
  • 2.  RE: Problems with 802.1x authentication using docking stations
    Posted Oct 31, 2024 01:20 PM
    Are the devices managed or unmanaged?
    Managed devices should automatically apply the 802.1X configuration to any/all Ethernet interfaces.
    Carson Hulcher, ACEX#110
  • 3.  RE: Problems with 802.1x authentication using docking stations
    Posted Nov 04, 2024 03:06 AM
    during testing the configuration was done manually in some PC test windows, but we can test a Gpo to see if the configuration is automatically applied to any interface, thanks for the feedback.
  • 4.  RE: Problems with 802.1x authentication using docking stations
    Posted Nov 01, 2024 06:39 AM
    Are these Windows hosts?  Are you pushing the 802.1x settings via GPO?
  • 5.  RE: Problems with 802.1x authentication using docking stations
    Posted Nov 02, 2024 08:28 AM
    Can you disable Mac randomization on the virtual adapter?
    Or if these are Windows domain members consider certificate based authentication
