Problems with clearpass and new lenovo docking stations
  • 1.  Problems with clearpass and new lenovo docking stations
    Posted Jul 04, 2024 06:13 AM
    hello community,
    since the introduction of the new laptops with the new lenovo docking stations we have problems with the clearpass 802.1x authentication.
    The clients are authenticated in wired mode.
    We have problems with the Lenovo 40B2 docking stations.
    In clearpass we only see Mac auths, the clients plugged into the docking station often have to be restarted a few times to see an 802.1x auth with TLS.
    We have already found out that the docking station stays permanently connected to the network, apparently because of wacke on lan.
    And during this time (even if no client is connected) Mac does auth...
    Has anyone ever had a similar problem?
    Can this be switched off on the docking stations?
    Or is there another workaround?
    Many thanks in advance ;-)
    Tobias
  • 2.  RE: Problems with clearpass and new lenovo docking stations
    Posted Jul 04, 2024 07:58 AM
    When I search for that specific docking station, I see more people having this issue. The solution would be that the docking station would perform a 'EAP-Logoff', but that doesn't seem to be implemented. However, there appears to be firmware update for the docking station, which you may try and see if it improves the behavior although the release notes don't show any indication for that. The docking station should bring the link to the switch down if the laptop is disconnected from it.
    You may also decrease the reauthentication timeout, so that the switch will require reauthentication more often. This should be balanced against the authentication overhead, and depending on how many of these docking stations you have, could work or may make things even worse.
