Bonjour David,
Ca ressemble à un souci hardware => ouvre un RMA !
PowerArubaCL: Powershell Module to use Aruba Central
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Apr 17, 2025 05:31 AM
Subject: Problème Module Interface erreur Aruba 6300m
Bonjour a tous
Petit problème réccurent sur un switch Aruba 6300m
Une erreur Thermals coupe les ports en question et je ne parviens pas à les redémarrer
J'aimerais aussi connaître la signification de cette erreur.
4/1-PHY-17-24
Status Fault
Location External phy ports 17 to 24
Current 0 C
Min 0 C
Max 41 C
show interface 4/1/17-4/1/23
Interface 4/1/17 is down
Admin state is up
State information: Module interface error
Link state: down for 8 days (since Tue Apr 08 22:08:37 CEST 2025)
show environement
4/1-PHY-01-08 line-card-module 33.00 C normal
4/1-PHY-09-16 line-card-module 34.00 C normal
4/1-PHY-17-24 line-card-module 0.00 C fault
4/1-PHY-25-32 line-card-module 0.00 C fault
4/1-PHY-33-40 line-card-module 37.00 C normal
4/1-PHY-41-48 line-card-module 35.00 C normal
4/1-Switch-ASIC-Internal line-card-module 36.75 C normal
Merci d'avance pour vos retour!!
Google Translate:
Module Interface Error Problem
Hello everyone
Small recurring problem on an Aruba 6300m switch
A Thermals error is shutting down the ports in question, and I can't restart them.
I would also like to know the meaning of this error.
4/1-PHY-17-24
Status Fault
Current 0 C
Min 0 C
Max 41 C
Admin state is up
Thank you in advance for your feedback!
