There is no Authentication via SMS. When a user enters their information at the registration page, the password is then sent via SMS, using the cell phone number that the user entered in the registration page. It is no different from emailing a user the guest password.
Original Message:
Sent: Oct 06, 2021 11:42 AM
Subject: Process of Captive Portal Authentication with ClearPass Guest
hi guys,
I´d like to ask you, if someone can share a picture similar to the one Julián posted which shows the process for Guest Access using SMS authentication?!
Original Message:
Sent: Jul 21, 2017 03:47 PM
Hello guys,
I can't completely understand how captive portal authentication with ClearPass Guest works. Could anyone explain in more detail steps 3 to 5 of the below picture?
I have read something about in some point of the process the client sends the credentials directly to ClearPass (skipping NAD), ClearPass replies directly to the client (skipping NAD again) and then client sends the credentials to NAD and then NAD to ClearPass. Also I have read something about ClearPass POST the user credentials to the NAD device? All this sounds very weird to me. Is there any documentation of the entire process? I have only found the following article:
http://community.arubanetworks.com/t5/07-19-13-Expert-Day/How-does-captive-portal-authentication-really-work-with/td-p/87208
But this is not explained in detail. I have also found this:
http://www.arubanetworks.com/vrd/GuestAccessAppNote/wwhelp/wwhimpl/js/html/wwhelp.htm
Which is very well explained, but it doesn't include the part of ClearPass.
Julián
