Wired Intelligent Edge
Procurc 2910al (J9146A) firmware miss
  • 1.  Procurc 2910al (J9146A) firmware miss
    Posted Feb 01, 2018 09:47 PM
        I boot my 2910al, then console will stay in =>
     It seems FW miss.
    I try to down W_14_38.swi via xmodel
    =>do
    You have invoked the console download utility.
    Do you wish to continue? (Y/N)>Download was successful.
    Download file NOT an OS image, processing as ROM image...
    verifying crc, @ 05000008, len 21845
    crc = 68b3d67e
    ERROR: File @05000008 has bad CRC (ffffaaaa != 68b3d67e, len = 21845).
    ERROR: Download was unsuccessful. Fail boot burn.
    Anyone can help to repair it. Thanks
    BR,
    Orange
  • 2.  RE: Procurc 2910al (J9146A) firmware miss
    Posted Mar 13, 2018 05:27 AM
    Hi There,
    Aruba/Procurve switches has two flash memory locations for storing switch software.
    1)
    1. Delete the boot.ini file:
      =>rm cfa0/boot.ini
      Deleting the boot.ini file will result in a new boot.ini being created when during the next step.
    Thank can you try booting either with the primary or secondary flash . Use below command
    =>jp1 to boot of primary flash
    =>jp2 to boot of secondary flash
