Comware
  • 1.  ProCurve 1800-24G
    Posted Apr 23, 2008 09:34 AM
    Hiya,
    Does the the ProCurve 1800-24G model Gigabit switch have a stacking port on it? If so what is the throughput on it?
    Thanks/...
  • 2.  RE: ProCurve 1800-24G
    Posted Apr 23, 2008 10:01 AM
    Looking at the feature set on the ProCurve website I don't see any mention of stacking on this model.
    http://www.hp.com/rnd/products/switches/ProCurve_Switch_1800_Series/overview.htm
  • 3.  RE: ProCurve 1800-24G
    Posted Apr 23, 2008 11:27 PM
    I had one downstairs not is use. No it does not have a stacking port on it.
    Its a basic 24port +2 dual personality switch. Web Management only, so you loose some control.
