I have 3 Procurve 2520-24POE daisy chained with another 2 manageable switches. (no loop) All working fine.
I am not able to setup monitor port on any Procurve 2520 as following the instruction;
1. click Monitor Selected Ports (with black dot )
2. drop down menu and select monitoring port (say port 24 connect to analyzer)
3. select port(s) to be monitoring (say port 23)
4. Click Apply Changes.
I tried these many times on all three 2520, but get no result.
The only thing I have is on the VLAN, which has two entries:
VLAN ID #1 Default_VLAN(primary), Static, tagged ports=none, untagged ports=1-28
VLAN ID#10 VoiceLAN, Static, tagged ports=1-28, untagged ports=none
Don't understand is after I click "Apply Changes" it switch back to the screen of "monitoring off".
I have no way to confirm or reviewing any current monitoring setup.
Don't know what I'm missing.
Any assistance would highly appreciated.
Thank you.
