Comware
  • 1.  Procurve 2524 - MIBs
    Posted Jun 16, 2008 09:10 AM
    In my network I have some hp procurve 2524 and I would like to use the snmp protocols to receive the eventual alerts generated by the switch in case of troubles.
    I read the hp documentation and I found several MIBs you have to load on your manager in order to receive the trap. Below the list:
    Netswtst.mib
    Downld.mib
    Icf.mib
    Config.mib
    Vlan.mib
    Entity.mib
    I tried to find on the hp web site these files and I googled the above MIBs but with no luck. It seems that the MIBs are in the CD “TopTools for Hubs & Switch”…
    Can someone help me to download these MIBs?
    For info we use as manager the IBM “Netcool”.
    Thanks and Regards,
    Michele
  • 2.  RE: Procurve 2524 - MIBs
    Posted Jun 16, 2008 09:25 PM
    Hi Michele,
    You can find the MIBs here:
    http://www.hp.com/rnd/software/MIBs.htm
    Matt
  • 3.  RE: Procurve 2524 - MIBs
    Posted Jun 03, 2009 08:44 AM
    I have the same problem: I cannot find these MIBs they are not in http://www.hp.com/rnd/software/
