Skip main navigation (Press Enter).
Log in
Toggle navigation
Log in
Home
Discussion Forum
Support
Documentation Portal
Support Knowledge Base
HPE Networking Support Portal
HPE Aruba Networking Central Status
Live + Virtual Events
Webinar Archive
Upcoming Events
Threat Labs
News
Technical Blog
ACEX Hall of Fame
MVP Program
Become a Member
Comware
Community Home
Discussion
56.9K
Members
811
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
Procurve 2610 VLAN Voice
PEI_1
Feb 07, 2011 04:27 AM
Hi, switch1(config)#vlan 10 switch1(vlan-10)#name voice switch1(vlan-10)#voice Can someone advise the ...
EckerA
Feb 08, 2011 12:52 AM
Hi, the voice commands enables lldp-med on the vlan. hth alex
cenk sasmaztin
Feb 13, 2011 04:47 PM
you can use QoS type of service or L2 QoS for the voip comminication my advice use ToS priority ...
1.
Kudos
PEI_1
Posted Feb 07, 2011 04:27 AM
Reply Privately
Options Dropdown
Can someone advise the purpose of voice option for vlan as above?
Pei
2.
RE: Procurve 2610 VLAN Voice
Kudos
EckerA
Posted Feb 08, 2011 12:52 AM
Reply Privately
Options Dropdown
hth
alex
3.
Kudos
cenk sasmaztin
Posted Feb 13, 2011 04:47 PM
Reply Privately
Options Dropdown
you can use QoS
my advice use ToS
priority for voice port
for example
qos tcp-port 554 dscp 101110
qos type-of-service diff-services
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Related Content
QOS configutration for Mitel VOIP
PEI_1
Added Jan 30, 2011
Discussion Thread
3
LLDP-MED and QoS DSCP Marking
ukonstantin
Added Jan 21, 2016
Discussion Thread
4
QoS: DSCP Markings on Procurve Switches
Steffen Frederiksen
Added Apr 12, 2011
Discussion Thread
4
PEI_1
Added Jan 30, 2011
Library Entry
1950 QoS configuration for Voice vlan and observation of DSCP
mr_vaughn
Added Jul 13, 2018
Discussion Thread
2
Copyright 2024. All rights reserved.
Powered by Higher Logic
