Comware
  • 1.  ProCurve 2810 24G mini GBICs
    Posted Mar 31, 2010 12:36 PM
    We have two Procurve 2810:
    1x 2810 48G
    1x 2810 24G
    The switches are connected through mini gbics (J9021A)
    If i connect two switches together, there is no connection on the mini gbics.
    The Gbics are identified and correctly installed.
    If i connect the first switch to 3com switch through these mini Gbics no problem.
    The problem is:
    I can not connect these switches through one of the Gbics. Simply there is no link.
  • 2.  RE: ProCurve 2810 24G mini GBICs
    Posted Apr 01, 2010 12:31 AM
    what is the mini GBIC you are using, the product number of it i mean.
    Also for now check the fiber cable, switch the the cable (send and receive) and check
  • 3.  RE: ProCurve 2810 24G mini GBICs
    Posted Apr 01, 2010 04:50 AM
    I use:
    Procurve Gigabit-SX-LC Mini GBIC
    Part number: 1990-3662
    Product: J4858C
    Kabel type:
    Optronics 62 5/125 MM062
    Type: LCST62D0R2
  • 4.  RE: ProCurve 2810 24G mini GBICs
    Posted Apr 01, 2010 06:38 PM
    I'd also check that you have forced the port speed for the mGBIC port on both switches (int 49 speed-duplex 1000-full)
  • 5.  RE: ProCurve 2810 24G mini GBICs
    Posted Apr 06, 2010 02:31 AM
    Just check 3 things (in this order)
    1. May be one of the Gbics isn't plugged ok (just plug out and plug in)
    2. Define both port switches to Speed Auto and MDIX Auto
    3. Cross the one terminators (the lc connector) in the patch cable
    4. Good Luck!!!!
