Here is some more info about the exact setup, and how to cause the CPU
utilization to go nuts:
Two switches, constant configuration, and two possible wiring options:
Parent Switch: 5308XL
Child Switch: 2810-48G
Vlan Configuration:
Parent:
* Port E4: VLANs 1,2,19, and 3260 Tagged. None untagged.
* Port E2: VLAN 1 untagged, none tagged.
Child:
* Port 1: VLANs 1,2,19, and 3260 tagged. None untagged.
* Port 2: VLAN 1 untagged, none tagged.
The parent is the backbone switch to which many things are connected,
it handles lots of traffic and works great. The child has nothing
connected to it presently except it's link with the parent which I
change between wiring configuration A and B
Wiring Configuration A:
An ethernet cable is run between Parent:E2 and Child:2
Wiring Configuration B:
An ethernet cable is run between Parent:E4 and Child:1
In either configuration there is only one link between the parent and
the child, and nothing else is plugged into the child.
Now, whenever I am in wiring configuration A, the CPU utilization on
the child (2810) switch is low (3-5%). When I switch to wiring
configuratino B (i.e. unplug the cable and move it to the new ports)
the CPU utilization goes up to 45-55%, the interfaces (both telnet and
web) become very sluggish, and if I attach devices to it, packets are
dropped, ping times get high , etc.
I have three new 2810 switches, all with the N_10_09 firmware, and
have replicated this problem with two of them, so it doesn't seem to
be a hardware problem.
Anyone else seen anything like this?
