Comware
Procurve 9315m and SLB Teaming
  • 1.  Procurve 9315m and SLB Teaming
    Posted Feb 28, 2007 01:00 AM
    We have a procurve 9315m as core switch which P-Class Blade are connected to.
    I'd like to configure the Blade NIC teaming as SLB .
    So I looked for a way to configure the 2 ports on the switch as trunk , but couldn't find it in the WEB configuration page .
    The trunk configuration page is not very clear .
    Can anyone provide me instructions to correctly configure the SLB from the switch side , using CLI ?
    Thanks a lot
  • 2.  RE: Procurve 9315m and SLB Teaming
    Posted Feb 28, 2007 04:20 PM
    Hi Stefano,
    The information you are after is in the documentation for the 9313m from HP ProCurve's website.
    http://www.hp.com/rnd/support/manuals/93xx_6308.htm
    Below is the chapter specific to trunking:
    ftp://ftp.hp.com/pub/networking/software/9300m-Install-Jun2005-59906028-Chap07.pdf
    Just be aware that deploying trunks will require a reload on certain versions of firmware to deploy and generally speaking will require a reload across all versions at some stage.
    Good luck!
    Joel
