Comware
Procurve mac-based authentication virtual machine
  • 1.  Procurve mac-based authentication virtual machine
    Posted May 26, 2011 02:07 AM
    I'm using Procurves 2848 with mac-based authentication and MS IAS. It works very fine. But if I using windows 7 with xp-mode and the virtual machine is using the network card of the host then the virtual machine get no access to the network. I can ping the network card of the host and if I switch off the mac-based authentication at the port it works. Has anyone a solution for that problem?
    Thanks in advance.
    Andreas Micklich
  • 2.  RE: Procurve mac-based authentication virtual machine
    Posted May 26, 2011 07:17 AM
    set parameter addr-limit to 2
