That will not work. The letter (Y, U) stand for the hardware platform/architecture. Different letter means different platform and likely CPU/memory/etc are different, so the 'U' firmware is incompatible with switches/platforms that use the 'Y' firmware.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Apr 18, 2025 09:36 AM
Subject: ProCurve Switch 2510G-24 (J9279A) firmware update
Hi Parnassus,
Thanks for the quick reply. I figured Y.11.52 was the latest, but when I search the HPE Networking Support Portal for J9280A it also shows U.11.67 so I was wondering if that firmware would work on the older J9280A, even though the Release Notes don't mention J9280A. The Release Notes says it supports "HPE 2510 48 Switch Series".
As for why I was looking for a GUI instead of the CLI, it is because the 400+ page manual is not easy to find things in. I was trying to see how to add console users, or change console user passwords and it wasn't immediately obvious how to do those things.
Thanks again for the prompt reply.
Ari
Original Message:
Sent: Apr 18, 2025 07:09 AM
Hello Ari, I confirm that Y.11.52 (20-05-2018) was the latest Y Software Build available for that EoS/EoL Switch SKU (J9279A ProCurve Switch 2510G-24). You can't expect anything newer due to its declared EoS/EoL status.
Now the real question: why you explicitly need a Web Interface access when such of a switch is very easily manageable via its CLI (through physical Console or via SSH/Telnet connections)?
Original Message:
Sent: Apr 17, 2025 12:19 PM
I know that this is a really old question (about really old switches) but we still have a few and we can't get into the web interface because it requires a version of Java which we don't have available. Is there any newer firmware for these switches than Y.11.52 that works with a more modern browser?
Otherwise, does anyone have any suggestions (besides a time-machine) for using the web interface on these switches?
Ari
Original Message:
Sent: Sep 01, 2018 05:24 AM
Latest Y.11.52 uses the same BootROM version of first Y.11.12 (Y.11.52 uses BootROM N.10.02 as Y.11.12 does) so you can safely update Y.11.12 directly to Y.11.52 (no automatic double reload will happen since BootROM will not be updated during the update of System software).
