  • 1.  Procurve Switch 5406Zl with MSM765zl WESM
    Posted Aug 03, 2011 04:34 AM
    I have got Procurve 5406zl switch with the K.14.54, ROM K.12.20 firmware.
    I have recently purchased MSM765zl module to get the WIFI configured.
    I am not able to get the module to get registered with the switch, even after restarting the switch.
    I get error msg when I enter wireless-services e ( where e is the slot ID )
    wireless-services e
    e: is not a Wireless Services module.
    Can anyone help me on this ?
    Regards
    Rohith
    P.S. This thread has been moved from Communications, Wireless (Legacy ITRC forum) to MSM Series. - Hp forum Moderator
  • 2.  RE: Procurve Switch 5406Zl with MSM765zl WESM
    Posted Aug 03, 2011 05:50 AM
    The 765zl isnt activated like old WESM modules, you use it like an ordinary service module.
    "show service e" should give you some info and "service e 1" should put you in the boot rom of the service module.
  • 3.  RE: Procurve Switch 5406Zl with MSM765zl WESM
    Posted Aug 03, 2011 07:10 AM
    Hi
  • 4.  RE: Procurve Switch 5406Zl with MSM765zl WESM
    Posted Aug 03, 2011 07:45 AM
    The controller have two integrated ports; Internet and LAN, on the 765zl they are connected via 10GbE backplane ports. They'll show up in your switch as e1 and e2.
    Have a look at this doc: http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c02728169/c02728169.pdf specially page 2-3 and onwards. It probably will get you started!
