Hi, we have a full Procurve infra-structure. Our 2 main server switches are Procurves 2810-48G and our edges switces are the 2610-48G-PWR.
We recently bought an IBM Blade Center and it came with Cisco 3012 switches.
We made 4 different LACP port Trunks out of the 4 external interfaces of the Ciscos towards our 2 main 2810 Procurves.
That gives us 4Gig Trunks out of each ciscos.
For some reasons this ALMOST works. For some reasons 2 of the 4ports Trunks are going down.
I don't have much logging in the Procurves about this issue, only the following when it occures:
I 09/22/10 19:13:01 ports: port 17 in Trk1 is now off-line
I 09/22/10 19:13:01 ports: port 18 in Trk1 is now off-line
I 09/22/10 19:13:01 ports: port 35 in Trk1 is now off-line
I 09/22/10 19:13:01 ports: trunk Trk1 is now inactive
I 09/22/10 19:13:01 ports: port 36 in Trk1 is now off-line
The Ciscos side is a bit more chatty...
- 1d05h: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Gi0/15, putting Gi0/15 in err-disable state
- 1d05h: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Gi0/16, putting Gi0/16 in err-disable state
- 1d05h: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Gi0/17, putting Gi0/17 in err-disable state
- 1d05h: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Gi0/18, putting Gi0/18 in err-disable state
- 1d05h: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Po1, putting Gi0/15 in err-disable state
- 1d05h: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Po1, putting Gi0/16 in err-disable state
- 1d05h: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Po1, putting Gi0/17 in err-disable state
- 1d05h: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Po1, putting Gi0/18 in err-disable state
- 1d05h: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Po1, putting Po1 in err-disable state
- 1d05h: %PM-4-ERR_DISABLE: lsgroup error detected on Gi0/1, putting Gi0/1 in err-disable state
- 1d05h: %PM-4-ERR_DISABLE: lsgroup error detected on Gi0/3, putting Gi0/3 in err-disable state
- 1d05h: %PM-4-ERR_DISABLE: lsgroup error detected on Gi0/4, putting Gi0/4 in err-disable state
I just don't know where to start looking has far as what is our ROOT cause issue.
If I go to the cisco and do a shut/no shut on the po1 (Trunk) interface...the link comes back on-line for many hours... and it eventualy goes down again.
Would could cause this to be so unstable?
Andy
P.S. This thread has been moved from Switches, Hubs, Modems (Legacy ITRC forum) to ProCurve / ProVision-Based. - Hp Forum Moderator
