profiling manually added devices on endpoint repository
  • 1.  profiling manually added devices on endpoint repository
    Posted Jul 18, 2017 02:48 PM
    We have got some devices that does not support 802.1x and we are manually adding them with a mac authentication on clearpass.
    How can i profile those manually added devices on endpoint repository?
    i see that for example other devices that for examlpe join the network with social media or things liek that get profiled but the manually added on the endpoint repository never get profiled
    How can i  profile them?
    Cheers
    Carlos
  • 2.  RE: profiling manually added devices on endpoint repository
    Posted Jul 18, 2017 03:04 PM
    Subnet scan should work.
  • 3.  RE: profiling manually added devices on endpoint repository
    Posted Jul 18, 2017 11:21 PM
    thanks tim
    It is possible to kno when it was manually added? for example when you profile it, it tells you when it was added(i mean the date when it was added to endpoint repository.  But when you manually add it, it wont show when it was added
