  • 1.  Promote Subscriber to Publisher
    Posted Jan 02, 2025 02:16 AM
    Currently, our cluster consists of three nodes: Node A is the publisher, Node B is the subscriber, and a Virtual IP is configured between Node A and Node B. If I promote Node C to be a publisher, what prerequisites should I prepare?
  • 2.  RE: Promote Subscriber to Publisher
    Posted Jan 02, 2025 03:08 AM
    • Backup your database configuration
    • Disable cluster wide parameters under standby publisher > Enable Publisher Failover > FALSE
    • Keep in mind that if there are Licenses there on that node, they will be de-activated. Please contact support to re-activate the licenses
    • Versions of Clearpass Nodes must be the Same (version and Subversion)
    Shpat | ACEP | ACMP | ACCP | ACDP |
    -Just an Aruba enthusiast and contributor by cases-
  • 3.  RE: Promote Subscriber to Publisher
    Posted Feb 20, 2025 12:27 AM
    Additionally, we are currently running version 6.11.10. If I click 'Promote to Publisher,' what will happen, and how long should we expect the process to take?
  • 4.  RE: Promote Subscriber to Publisher
    Posted Feb 24, 2025 06:12 AM
    If you click 'promote to publisher' the subscriber on which you perform the action will take the publisher role and the current publisher drops to subscriber.
    In the output of the CLI command you can see the steps that are performed.
    As part of the process both the new and old publisher will do a 'warm restart' of all processes running, which results in a short downtime which depends on the appliance size and database/policy complexity, but I would think in minutes. You can check a restart of all services to see how long that takes in your environment.
    Note that promoting a subscriber to publisher is not something you should do on a regular basis, it's normally only done in case the publisher is lost for longer time (hours/days).
