10.15.1001 is only available for the CX-8325H switches. For upgrades, please use 10.15.1005.
The following info is from the release notes for 10.15.1001 (only 8325H)
10.15.1001 comes factory-installed on the initial release of the 8325H Switch series, and is supported on this switch series only. Best practices is to upgrade your 8325H switch to the latest version of 10.15.xxxx when newer software comes available.
Willem Bargeman
Systems Engineer Aruba
ACEX #125
Original Message:
Sent: Mar 05, 2025 06:05 PM
Subject: Proper Release Notes for v10.15.1xxx
Also, I see there is release notes for v10.15.0005 and .1005 however Central only has .0005 and .1001 available firmware?
When will .1005 be available?
Where is the .1001 release notes?
Original Message:
Sent: Feb 25, 2025 12:39 PM
Point taken.
I've shared you're feedback internally.
Willem Bargeman
ACEX #125
Original Message:
Sent: Feb 25, 2025 10:06 AM
Sadly, to me it looks like a bad move.
Despite being on, as example, a particular Switch's Software download page, the two Release Note links (icon and string) on that page aren't not only linked to the same PDF anymore (OK...) but, and I find it really annoying, they both land us to a general Switches homepage and a deeper (re)selection to finally reach the desired Release Note HTML page (after drilling down the build too) is necessary. Try it yourself.
Original Message:
Sent: 2/25/2025 4:59:00 AM
Subject: RE: Proper Release Notes for v10.15.1xxx
Hi Davide,
Starting from 10.15 release notes are not published in PDF format anymore.
Willem Bargeman
ACEX #125
Original Message:
Sent: Feb 25, 2025 04:44 AM
Hi Willem, do you know if HPE will publish (I was not able to find them) the typical Release Notes' PDF documents about AOS-CX 10.15 builds, if there will be any as in the past? Cheers, Davide.
Original Message:
Sent: Feb 24, 2025 07:56 AM
Release Notes for AOS-CX can be found here.
https://arubanetworking.hpe.com/techdocs/AOS-CX/Consolidated_RNs/Portal_Home/Content/cx-home.htm
Specifically for the 10.15.1000 release use the following link: https://arubanetworking.hpe.com/techdocs/AOS-CX/Consolidated_RNs/HTML-6300-6400/Content/10_15/1005/overview.htm
Willem Bargeman
ACEX #125
Original Message:
Sent: Feb 24, 2025 03:17 AM
Hi all,
Does anyone know where proper release notes for v10.15.1xxx?
It seems that HPE has changed the release notes space and now I can't read any details on what has changed and improved.
