  • 1.  Provision 275
    Posted Jan 05, 2015 10:22 AM
    This Just Started...
    Any Thoughts
    This error appears when I try to put the AP provision ,
    Error browser
    "Not all IPSec parameters are set; please set the remaining parameters"
    Name:Aruba Operating System Software.
    Model:Aruba3600
    Version:6.4.2.0
    AP 275
  • 2.  RE: Provision 275
    Posted Jan 05, 2015 10:33 AM
    Are you trying to provision the AP as a remote AP?
    Or are you deploying as a campus AP?
  • 3.  RE: Provision 275
    Posted Jan 05, 2015 10:35 AM
    The workaround is to do it using the CLI command :
    provision-ap copy-provisioning-params ap-name 00:00:00:00:00:00
    provision-ap installation default
    provision-ap ipaddr 1.1.1.1.
    provision-ap netmask 255.255.255.0
    provision-ap gateway 1.1.1.254
    provision-ap dns-server-ip 1.1.1.253
    provision-ap domain-name domain.net
    provision-ap no external-antenna
    provision-ap server-name aruba-master
    provision-ap ap-group "Group1"
    provision-ap ap-name "AP1"
    provision-ap no syslocation
    provision-ap mesh-role none
    provision-ap no fqln
    provision-ap reprovision ap-name 00:00:00:00:00:00
    But you should consider upgrading to a later code that has a fix for that.
  • 4.  RE: Provision 275
    Posted Jan 05, 2015 10:36 AM
    HI Campus ...
    It is happing to all my Ap
    Every change is giving the Error
  • 5.  RE: Provision 275
    Posted Jan 05, 2015 10:51 AM
    I would suggest upgrading to 6.4.2.3. There are lots of bug fixes in that release (it's GA now), and it has some specific fixes for the AP-275 that might resolve issues that could later plague you once you resolve this issue.
  • 6.  RE: Provision 275
    Posted Jan 05, 2015 11:20 AM
    Up graded the code to 6.4.2.3 GA release.
    Still have Error
    Starting support case.
  • 7.  RE: Provision 275
    Posted Jan 05, 2015 11:29 AM
    try refreshing your browser or try another one
  • 8.  RE: Provision 275
    Posted Jan 05, 2015 02:43 PM
    Disable any auto-form fill applets or plugins on your browser. I've seen that regularly with people who have that enabled on their browsers. You other option is to check then uncheck the ipsec settings checkbox to clear the field that the browser tried to autopupulate.
  • 9.  RE: Provision 275
    Posted Jan 06, 2015 02:56 AM
    I would try starting a browser cleanly with no add ins and be sure the cache is clear. If you have another computer it's worth trying that as well.
