  • 1.  Provision RAP-5WN
    Posted Dec 01, 2011 02:07 PM
    Hey everyone!
    I have a brand new rap-5wn sitting here and I just can't get it to see the controller. Let's see if I can list what I have done:
    1. firewall configuration is set to allow port 4500 to the aruba 3400 controller - I see 3 hits on the rule, but it doesn't seem to be reaching the controller. (not sure....)
    2. On the aruba 3400 in VPN\ipsec configured and address pool,
    3. in security/authentication/servers/l3 authentication set to default
    4. created a remote ap access policy (security/firewall/policies) permitting svc-papi, svc-gre, svc-l2tp (any/any), and svc-tftp, svc-ftp (any mswitch)
    5. Now for configuring the l3 auth I'm having some issues - when I go to the default-rap, I dont see a roll that I can select and not sure what server group to pick(ldap, radius, default)
    So when I plug in rap, go to config it from an outside source I get a rc_error_Ikep1 error on a DSL modem that has no firewall enabled....
    So just what am I missing here?
    Any help would be appreciated - they want to ship this unit out as soon as possible.
    thank you!
    lirria
    #3400
  • 2.  RE: Provision RAP-5WN
    Posted Dec 01, 2011 02:14 PM
    Is the RAP-5WN in the  RAP Whitelist  as well ?
    Also, in the output of  ' show datapath session table | inc 4500 '   do you see the RAP trying to connect ?   That output would tell you if the RAP is making it through to the controller (or not)
  • 3.  RE: Provision RAP-5WN
    Posted Dec 01, 2011 02:30 PM
    I did add the mac0 to the rap whitelist, I get an error when I try the |inc 4500 so not sure what's going on there
    I do see one connection to port 4500
    Source ip is the controller destination ip is the DSL router that the rap is hooked to
    Lirria
  • 4.  RE: Provision RAP-5WN
    Posted Dec 01, 2011 02:36 PM
    ok - I did get the inc to work (have to type include apparently...)
    And I do see 2 connections on from the controller to the rap and 1 from the rap to the controller.
    It may have something to do with my firewall - It's a cisco asa 5510 if that helps.
    Lirria
  • 5.  RE: Provision RAP-5WN
    Posted Dec 01, 2011 02:58 PM
    WOOHOO got it! I had to add udp/isakmp to my access rule on the firewall and then boom up it came!
    Now to test the silly thing not in the office.....
    Thank you!
    Lirria
  • 6.  RE: Provision RAP-5WN
    Posted Dec 01, 2011 03:26 PM
    Nice work!
  • 7.  RE: Provision RAP-5WN
    Posted Dec 02, 2011 02:51 PM
    You ever have one of those days where you see something and get all excited because you think it's working and then realize you plugged the device *inside* the firewall and that's why you could see it?
    *sigh*
    So Its down to the firewall config is the issue and I just haven't found the right thing to fix it
    It's a cisco asa 5510 I have added nat-tranversal, nat-control, verified the port assign to the internal nat object and I'm out of ideas...
    any thoughts? (and yes I don't expect cisco experts... just hope for some thoughts)
    Lirria
  • 8.  RE: Provision RAP-5WN
    Posted Dec 02, 2011 02:59 PM
    I have access lists that look like this:
    access-list inbound-traffic-on-outside extended permit udp any host Aruba-external eq 4500
    access-list inside_access_in extended permit udp host Aruba-internal any eq 4500
    and I do feel like I'm missing something but I think I've been staring at it way to long.
    Lirria
  • 9.  RE: Provision RAP-5WN
    Posted Dec 02, 2011 03:37 PM
    What version of firmware are you running on your ASA?
  • 10.  RE: Provision RAP-5WN
    Posted Dec 02, 2011 03:43 PM
    8.0(4)
  • 11.  RE: Provision RAP-5WN
    Posted Dec 02, 2011 04:51 PM
    OK -
    I really did find the problem this time - Since my old controller was inside only - i never set up a default gateway for it so it had no idea where to send the traffic to the remote aps.
    now just to get the new ap accepting clients and i can ship thing.
    Thanks all!
    Lirria
