  • 1.  Provisioning IAP to remote AirWave server
    Posted Aug 07, 2015 11:57 AM
    Hi everyone.
    Just read the startup manual "Setting up Aruba Instant and Airwave"
    But it's a scenario when airwave and IAP's are in the same subnet.
    How to provision the IAP's to the remote AirWave server behind firewall?
  • 2.  RE: Provisioning IAP to remote AirWave server
    Posted Aug 07, 2015 01:42 PM
    As long as port 443 to Airwave is open, you can provision your IAPs to talk to it.
  • 3.  RE: Provisioning IAP to remote AirWave server
    Posted Aug 07, 2015 03:22 PM
    Yes...keep in mind that the communication for IAP and Airwave is ALWAYS initiated and sourced FROM the IAP.  Because of this, Airwave doesn't need to know the remote network IP ranges/subnets and thoeretically, ALL IAPs can be behind a NAT'ed router.  What you do need is 443 opened and Airwave reachable on the public internet if this is the deployment.  If that is the case, you can enable IAP whitelisting so that only subnets you designate are able to log into the Airwave UI.
