Developer
pyCentral token management
  • 1.  pyCentral token management
    Posted Nov 01, 2024 01:37 PM
    Edited by mroe1234 Nov 01, 2024 02:06 PM
    I'm having trouble using pyCentral and managing/refreshing tokens to my central on prem instance.  I am not using OAUTH, but just token access.  I assumed this code would work as expected, storing the most recent token and refresh token in the default token_store (/temp/tok_None_*****).  My central_info looks like:
    central_info = {
        "base_url": "https://apigw-cop.*********",
        "client_secret": "3jorSOIozX**************",
        "client_id": "KxOg******************************",
    def connect_to_central():
      ssl_verify = True
      central = ArubaCentralBase(central_info=central_info,
      ssl_verify=ssl_verify)
      central.refreshToken(central.getToken())
      central.storeToken()
      return central
    However, refreshToken seems to return the new token but not actually update the connection object?  So I have to do something like:
        ssl_verify = True
        newToken = central.refreshToken(central.getToken())
        newToken['grant_type'] = "refresh_token"
        central.storeToken(newToken)
        central.loadToken()
        return central
    Which also doesn't seem to work correctly.  At this point I am starting to believe that I am misunderstanding something fundamental and should stop poking and ask for some advice.  Ultimately, I am trying to write a script that periodically pulls data from Central On Prem, and "handles" token management.
  • 2.  RE: pyCentral token management
    Posted Nov 13, 2024 04:38 AM
    Do you have ask on github pycentral repo ?
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
