Developer
Python SDK and Ansible Collection for HPE Aruba Fabric Composer Released!
This thread has been viewed 16 times
  • 1.  Python SDK and Ansible Collection for HPE Aruba Fabric Composer Released!
    Posted Apr 09, 2025 12:11 PM
    Hello all! It is with great pleasure that I'm able to announce the publishing of the pyafc Python SDK and the HPEANFC Ansible Collection! You can find detailed guides on how to get started with these packages on our HPE Aruba Networking Developer Hub:
    Getting Started with Pyafc
    Getting Started with Ansible and HPEANFC
    To install these packages run the following commands:
    pip install pyafc
    ansible-galaxy collection install arubanetworks.afc
    Happy Automating!
    Ti Chiapuzio-Wong (they/them)
  • 2.  RE: Python SDK and Ansible Collection for HPE Aruba Fabric Composer Released!
    Posted Apr 15, 2025 04:09 AM
    Great news ! i will test soon !
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Python SDK and Ansible Collection for HPE Aruba Fabric Composer Released!
    Posted Apr 20, 2025 01:40 PM
    I'm having fun with the new Ansible collection!
    I wonder there is a way to get some debug info. I strugle with creating NTP assigned to a fabric. The task fails, but the NTP config is created. So some debugging may help figure out why it states to be failed.
    Next time I run the play it's green and listed as created.
    When the task fails my role stops, so it would be cool to figure out why I get an error.
    Test playbook:
    - name: Playbook test NTP
      hosts: platform_aoscx
      gather_facts: false
      tasks:
        - name: Configure NTP
          arubanetworks.afc.afc_ntp:
            afc_ip: "{{ config_context.afc_host }}"
            afc_username: "{{ afc_username }}"
            afc_password: "{{ afc_password }}"
            operation: 'create'
            data:
              name: "{{ config_context.afc_fabric }}-NTP"
              fabrics:
                - "{{ config_context.afc_fabric }}"
              servers:
                - server: "{{ config_context.ntp_servers.0.server }}"
        #          burst_mode: "iburst"
        #          perfer: true
          delegate_to: localhost
    running: ansible-playbook -l z16-leaf-1 test_ntp.yml -vvvv
    Output from task:
    TASK [Configure NTP] *************************************************************************************************************************************************************************
    task path: /home/arne/code/ao-fabric/test_ntp.yml:6
    <localhost> ESTABLISH LOCAL CONNECTION FOR USER: arne
    <localhost> EXEC /bin/sh -c 'echo ~arne && sleep 0'
    <localhost> EXEC /bin/sh -c '( umask 77 && mkdir -p "` echo /home/arne/.ansible/tmp `"&& mkdir "` echo /home/arne/.ansible/tmp/ansible-tmp-1745170667.2155805-29673-193779388731084 `" && echo ansible-tmp-1745170667.2155805-29673-193779388731084="` echo /home/arne/.ansible/tmp/ansible-tmp-1745170667.2155805-29673-193779388731084 `" ) && sleep 0'
    Using module file /home/arne/code/ao-fabric/collections/ansible_collections/arubanetworks/afc/plugins/modules/afc_ntp.py
    <localhost> PUT /home/arne/.ansible/tmp/ansible-local-29414o81onvid/tmpld88vr3z TO /home/arne/.ansible/tmp/ansible-tmp-1745170667.2155805-29673-193779388731084/AnsiballZ_afc_ntp.py
    <localhost> EXEC /bin/sh -c 'chmod u+x /home/arne/.ansible/tmp/ansible-tmp-1745170667.2155805-29673-193779388731084/ /home/arne/.ansible/tmp/ansible-tmp-1745170667.2155805-29673-193779388731084/AnsiballZ_afc_ntp.py && sleep 0'
    <localhost> EXEC /bin/sh -c '/home/arne/code/ao-fabric/venv/bin/python3 /home/arne/.ansible/tmp/ansible-tmp-1745170667.2155805-29673-193779388731084/AnsiballZ_afc_ntp.py && sleep 0'
    <localhost> EXEC /bin/sh -c 'rm -f -r /home/arne/.ansible/tmp/ansible-tmp-1745170667.2155805-29673-193779388731084/ > /dev/null 2>&1 && sleep 0'
    [WARNING]: Module did not set no_log for afc_password
    fatal: [z16-leaf-1 -> localhost]: FAILED! => {
        "changed": false,
        "invocation": {
            "module_args": {
                "afc_ip": "172.16.3.29",
                "afc_password": "xxxxxx",
                "afc_username": "admin",
                "auth_token": null,
                "data": {
                    "fabrics": [
                        "test_fabric"
                    "name": "test_fabric-NTP",
                    "servers": [
                            "server": "klokke.opdal.net"
                "operation": "create"
        "msg": "edfdb886-33f9-459c-9f03-f972101cc2b9"
    PLAY RECAP ***********************************************************************************************************************************************************************************
    z16-leaf-1                 : ok=0    changed=0    unreachable=0    failed=1    skipped=0    rescued=0    ignored=0
    Arne Opdal
