That's a great idea I'll try that.
Original Message:
Sent: Apr 01, 2025 06:01 AM
Subject: Question about QoS on Procurve switches
It's hard to say which traffic is placed in queue 1. By default AOS-S (Procurve) switches will trust the 802.1p tag in the packets. If the 802.1p tag is set to priority 1 the packets will be placed in queue 1. Queue 1 is also known as the background queue.
To find out which traffic is marked as background you can make a packet capture and filter on 802.1p tag 1. The switches can also log traffic using ACL's. With a MAC ACL you can match all traffic with CoS / 802.1p value 1. For example:
mac-access-list extended "300" 10 permit any any any cos 1 log 20 permit any any any exit
Then apply the MAC access list on 1 or more VLANs.
Willem Bargeman
Systems Engineer Aruba
ACEX #125
Original Message:
Sent: Mar 13, 2025 05:09 PM
I setup QoS on our network switches which are all Procurve/Aruba. If I look at the command, show interface queues [port number,] I can see if there are any drops due to congestion.
When I do that command on the ETH interface that connects to our Aruba wireless controller, I see the most drops in Q1:
switch# sh interface queues a17
Status and Counters - Port Counters for port A17
Link Status : Up
Port Enabled : Yes
Port Totals (Since boot or last clear) :
Rx Packets : 1,121,417,377 Tx Packets : 1,157,635,163
Rx Bytes : 3,134,138,169 Tx Bytes : 4,060,872,517
Rx Drop Packets : 0 Tx Drop Packets : 615,860
Rx Drop Bytes : 0 Tx Drop Bytes : 866,746,192
Egress Queue Totals (Since boot or last clear) :
Tx Packets Dropped Packets Tx Bytes Dropped Bytes
Q1 347,175,323 528,989 378,345,756,886 742,624,654
Q2 910,876 0 379,784,933 0
Q3 720,055,318 86,589 531,821,082,168 123,714,184
Q4 2,890,254 26 3,492,622,776 37,544
Q5 37,539,447 31 34,274,523,625 44,270
Q6 33,740,343 225 27,541,578,923 325,540
Q7 12,726,796 0 7,069,669,915 0
Q8 2,596,839 0 388,447,992 0
Looking at the switches, it appears that Q3 is priority 0 and guaranteed 30 percent of the bandwidth. I believe this to be normal traffic (best effort) probably Internet browsing, etc.
Can anyone tell me what type of traffic is in Q1? I'm wondering what is getting dropped, and what type of traffic that is? according to what I'm seeing in the switch, this is categorized as priority 1. I'm just using the Procurve defaults:
Egress Queue Configuration
Number of Queues: 8
Queue | 802.1p Priorities
1 1
2 2
3 0
4 3
5 4
6 5
7 6
8 7
Outbound Guaranteed Minimum Bandwidth %
Port Q1 Q2 Q3 Q4 Q5 Q6 Q7 Q8
A1 2 3 30 10 10 10 15 20
