Cloud Managed Networks
Radio down for all Access Point
This thread has been viewed 47 times
  • 1.  Radio down for all Access Point
    Posted Aug 05, 2022 03:09 AM
    Hi
    I have new Aruba 635 AP which I am trying to connect to Cloud central. After registering and initial configuration AP is visible as online and applied to designated group. Group has SSID configured, but AP shows Radio down, in audit trail configuration is synchronized but all Radio 2.4,5 & 6, are  shown
    • DISABLED
    • DISABLED
    • DISABLED
    How can I enable the Radio for these AP.
  • 2.  RE: Radio down for all Access Point
    Posted Aug 05, 2022 05:17 AM
    Did you select your country in the system tab? Also enable IPM if your power budget is limited on the switch.
    Sietze
  • 3.  RE: Radio down for all Access Point
    Posted Aug 05, 2022 05:42 AM
    Hi
    Yes, AP country is selected. Also IPM is enabled. My Switch is POE+. I have attached Tech output command as well.
    Attachment(s)
    txt
    output_94_64_24_c1_45_e4.txt   310 KB 1 version
  • 4.  RE: Radio down for all Access Point
    Posted Aug 05, 2022 06:48 AM
    I suggest to upgrade to the latest maintenance release of 8.9.x which is 8.9.0.3
  • 5.  RE: Radio down for all Access Point
    Posted Aug 05, 2022 06:57 AM
    Tried to upgrade the firmware to 8.9.0.3 but received below error.
    Upgrade: Failed in device due to download image fail
    Tried several time.
    <app-grid-refresh _ngcontent-hrn-c2="" _nghost-hrn-c20=""></app-grid-refresh>
    <app-grid-search _ngcontent-hrn-c2=""></app-grid-search><app-grid-actions _ngcontent-hrn-c2="">
    <mat-divider class="mat-divider mat-divider-vertical ng-star-inserted" role="separator" aria-orientation="vertical"></mat-divider>
    </app-grid-actions>
  • 6.  RE: Radio down for all Access Point
    Posted Aug 05, 2022 06:59 AM
    have you allowed both HTTPS and HTTP access for Aruba Central to get to your APs?
  • 7.  RE: Radio down for all Access Point
    Posted Aug 05, 2022 08:07 AM
    I can't find the http & https access configuration, however under the system AP has webUI enabled.
  • 8.  RE: Radio down for all Access Point
    Posted Aug 05, 2022 08:51 AM
    Thanks Ariyap, after upgrading the AP Firmware to 8.9.0.3 Radio for 2.4 & 5 got enabled. I am little confuse why Aruba will ship with the version which has significant problem.
    Anyway Thanks very much for the help.
  • 9.  RE: Radio down for all Access Point
    Posted Aug 08, 2022 08:58 AM
    Depending on where you live, the AP may or may not be approved by your local authorities. What probably happened is that by upgrading the AP from 8.9.0.2 to 8.9.0.3, you also upgraded the so-called DRT, which records which APs on what channels and power are allowed in every country.
    In another country, the AP probably would have worked, and your reseller might have informed you about that. Also the leaflet that comes with the AP has a recommendation: "An upgrade to the AP firmware and/or downloadable regulatory table (DRT) file to the latest available version is recommended."; but I have to admit that I had to look such a leaflet up as I most times try to make things work and read the manual if nothing else happens ;-)
    From the people that make these APs, I understood that they can't wait for the AP to be certified in all countries before they start manufacture and put initial firmware on the AP in the factory. Unfortunately this wasn't fully clear in your case.
  • 10.  RE: Radio down for all Access Point
    Posted Aug 05, 2022 07:55 AM
    Did you enabled the radios?
  • 11.  RE: Radio down for all Access Point
    Posted Aug 05, 2022 08:02 AM
    Yes, Radio are enable for 2.4GHz & 5GHz
