  • 1.  Radio not activated on IAP535 and 534 terminals
    Posted Mar 20, 2025 06:32 AM
    We have a cluster of 38 terminals made up of IAP535 and 534 terminals and we have been experiencing the following problems since they were commissioned:
    1) some terminals don't activate their radios on both frequency bands;
    2) in addition to not mounting their radios, other terminals can't reach the controller even though the network configuration is correct. Namely, the terminal responds to ping.
    My question is this:
    All the terminals are connected to Cisco 9200 POE+ switches. I've read that POE+ is the minimum power required to operate the terminals, but could this be the cause of our problems?
    A minimum POE power supply limits us to what function?
    How can I find out why they don't start their radio?
    Thanks in advance for your help.
    PS: the terminals are in version 8.12.0.3
    Laetitia,
    TELLIER-LAROUANNE Laetitia
  • 2.  RE: Radio not activated on IAP535 and 534 terminals
    Posted Mar 20, 2025 09:52 AM
    If the AP is only getting 802.3af negotiated then the AP isn't going to operate the radios.
    1. Make sure that LLDP is enabled on the switch and switch ports, LLDP is required to negotiate PoE at 802.3at or higher.
    2. Enable IPM on the AP to handle power constrained situation.
    Carson Hulcher, ACEX#110
  • 3.  RE: Radio not activated on IAP535 and 534 terminals
    Posted Mar 20, 2025 10:13 AM
    The switches currently deliver 27.5W to the terminals and LLDP is active on the switch and ports.
  • 4.  RE: Radio not activated on IAP535 and 534 terminals
    Posted Mar 20, 2025 10:28 AM
    And the AP-530 is an 802.3bt device by default.  Enable IPM to allow the AP to operate normally when not power constrained.
    Check "show ap power-mgmt-statistics" to see the AP's current power status.
  • 5.  RE: Radio not activated on IAP535 and 534 terminals
    Posted Mar 20, 2025 11:05 AM
    We're using a virtual controller. If I type in this command, it sends us information about the master terminal.
    How can I get the information for the terminals affected by the problem? (because it's not on the controller's master terminal that we have the problems).
    What are the risks of activating the IPM on the controller?
  • 6.  RE: Radio not activated on IAP535 and 534 terminals
    Posted Mar 20, 2025 11:11 AM
    Enabling IPM doesn't have a downside, as the feature only gives you more control over the behavior when power is restricted.
    You can use SSH to login to the specific AP to reach the CLI, you can also use the Support option to run commands against a specific AP.
  • 7.  RE: Radio not activated on IAP535 and 534 terminals
    Posted Mar 21, 2025 02:42 AM
    well you mentioned you had Instant APs, and you can enable IPM through the CLI or if you have Aruba Central, you can do it through there as well.
  • 8.  RE: Radio not activated on IAP535 and 534 terminals
    Posted Mar 21, 2025 04:28 PM
    There should not be a  need to enable IPM if the AP-53x is powered by class 4 POE (802.3at). Even with IPM off, this AP should only disable USB and the secondary Ethernet port. There should not be any impact on the radio performance or functionality
    /Onno Harms
    Wireless Platforms Product Management
    HPE Aruba Networking
  • 9.  RE: Radio not activated on IAP535 and 534 terminals
    Posted Mar 21, 2025 04:56 AM
    This may also be a 'regulatory domain' conflict. What is the country that you operate the APs in?
    If you can login to the CLI (either SSH, or serial console, or use the webUI menu Support) and run the command:
    50825# show ap allowed-channels
    Allowed Channels for AP Type 515 Country Code CH
    PHY Type                  Allowed Channels
    2.4GHz (indoor)           1 2 3 4 5 6 7 8 9 10 11 12 13
    5GHz (indoor)             36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
    2.4GHz (outdoor)          1 2 3 4 5 6 7 8 9 10 11 12 13
    5GHz (outdoor)            100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
    2.4GHz 40MHz (indoor)     1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    5GHz 40MHz (indoor)       36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136 149-153 157-161
    2.4GHz 40MHz (outdoor)    1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    5GHz 40MHz (outdoor)      100-104 108-112 116-120 124-128 132-136 149-153 157-161
    5GHz 80MHz (indoor)       36-48 52-64 100-112 116-128 149-161
    5GHz 80MHz (outdoor)      100-112 116-128 149-161
    5GHz 160MHz (indoor)      36-64 100-128
    5GHz 160MHz (outdoor)     100-128
    5GHz (DFS)                52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
    5GHz (ZWDFS)              enable
