  • 1.  Radio power levels
    Posted Nov 11, 2014 10:27 AM
    Is there a way to control both radio's power on an IAP-225?  I set one setting in the GUI for min/max tx power, but that's it.  I set the min/max to 15dBm which seems to only apply to 5GHz.  When I issue "show ap bss-table", 2.4 is operating at 21dBM.  Any thoughts?
  • 2.  RE: Radio power levels
    Posted Nov 11, 2014 10:35 AM
    MASTER-MESH-PORTAL# show  arm config
    Minimum Transmit Power            :9
    Maximum Transmit Power            :18
    Band Steering Mode       :prefer-5ghz
    Client Aware             :enable
    Scanning                 :enable
    Wide Channel Bands       :5ghz
    80Mhz Support            :disable
    Air Time Fairness Mode   :preferred-access
    Client Match             :enable
    CM NB Matching Percent   :75
    CM Calculating Interval  :30
    CM SLB Threshold         :2
    CM SLB Balancing Mode    :channel based
    CM Max Request           :5
    CM Max Adoption          :5
    CM Debug Level           :error
    Custom Channels          :Yes
    2.4 GHz Channels
    MASTER-MESH-PORTAL# show ap bss-table
    Aruba AP BSS Table
    bss                ess      port  ip           phy   type  ch/EIRP/max-EIRP  cur-cl  ap name             in-t(s)  tot-t
    6c:f3:7f:b7:e4:d2  TULOABE  ?/?   192.168.1.3  a-HT  ap    100+/18/22        1       MASTER-MESH-PORTAL  0        21h:12m:36s
    6c:f3:7f:b7:e4:c2  TULOABE  ?/?   192.168.1.3  g-HT  ap    11/18/21          1       MASTER-MESH-PORTAL  0        21h:12m:34s
     What version of IAP Os are you running ? I am running the latest 4.1.1.1 and it looks like it works
  • 3.  RE: Radio power levels
    Posted Nov 11, 2014 11:14 AM
    4.1.1.1 as well.
    I set my 2.4 valid channels to 1 only and it's stuck on 6 so I may have a bigger issue here.  Going to reboot the IAP to see if that helps.  Even if it does fix the issue of 2.4 and 5 power levels not matching, is it possible to independantly control their power?
  • 4.  RE: Radio power levels
    Posted Nov 11, 2014 11:21 AM
    Maybe a 225 issue ? I am using an IAP135
  • 5.  RE: Radio power levels
    Posted Nov 11, 2014 11:23 AM
    Unfortunately you can't set that individually , Feature Request ?
  • 6.  RE: Radio power levels
    Posted Nov 12, 2014 08:31 AM
    Thanks for the info, Victor.
