See below for example Tx radio stats.
Probably ‘rcvd’ means 'received'. Does this mean that this is about frame/bytes from clients to AP that don’t have AP as end-destination so AP is sending it through? Mostly that would be to the LAN, but then it shouldn’t be a radio stats. Can someone explain the meaning of ‘rcvd’?
I can't see a total Tx frames line. To know this, should lines which lines should be added?
Tx Time perct @ beacon intvl 5 5 5 5 5 5 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
Tx Frames Rcvd 9655175
Tx Bcast Frames Rcvd 94255
Tx Frames Dropped 38784
Tx Bcast Frames Dropped 0
Tx Frames Transmitted 6574386
Tx Bytes Rcvd 2903395841
Tx Bytes Transmitted 2379748390
Tx Time Frames Rcvd 988644468
Tx Time Frames Dropped 3164948
Tx Time Frames Transmitted 855670420
Tx PS Unicast 0
Tx DTIM Broadcast 0
Tx Success With Retry 3325326
Tx Multiple Retries 3325326
Tx Mgmt Frames 69515031
Tx Mgmt Frames(PPS) 0
Tx Beacons Transmitted 66782785
Tx Beacons Transmitted(PPS) 0
Tx Probe Responses 2721958
Tx Probe Responses(PPS) 0
Tx Data Transmitted Retried 3325326
Tx Data Transmitted 6289330
Tx Data Frames 37040
Tx Broadcast Data Frames In 94255
Tx Data Bytes Transmitted 2180697871
Tx Data Bytes 2448099533
Tx Time Data Transmitted 827418336
Tx Time BC/MC Data 11074496
Tx Time Data dropped 3018256
Tx Time Data 922990292
Tx Time Data (Ideal) 678235064
Client Health Samples 2950704
Tx Broadcast Data Frames Sent 94249
Tx Broadcast Data Frames Sent(PPS) 0
Tx Multicast Data Frames 50795
Tx Multicast Data Frames(PPS) 0
Tx Workqueue Frames 7002276
Tx Bypass Frames 0
Tx DMO Multicast 0
Tx DMO Invalid 0
Tx DMO Converted 0
Tx DMO Replicated 0
Tx DMO Dropped 0
Tx DMO No Client 0
Tx DMO No BSSID 0
Tx Unicast Data Frames 6144286
Tx RTS Success 3537689
Tx RTS Failed 650782
Tx CTS Frames 0
Tx CTS Frames(PPS) 0
Tx Powersave Queue Timeouts 0
Tx Dropped After Retry 0
Tx Dropped No Buffer 358482
Tx Missed ACKs 958487
Tx Failed Beacons 10884
Tx Multi-Beacon Fail 0
Tx Long Preamble 0
Tx Short Preamble 3866055
Tx Beacon Interrupts 13358772
Tx Interrupts 0
Tx FIFO Underrun 70
Tx Allocated Desc 0
Tx Freed Desc 6549973
Tx EAPOL Frames 570
TX STBC Frames 1824478
TX LDPC Frames 5872399
TX OFDMA Frames 0
Tx AGGR Good 1300976
Tx AGGR Unaggr 2551217
Tx Data Priority [BK] 204214
Tx Data Priority [BE] 2156784
Tx Data Priority [VI] 193741
Tx Data Priority [VO] 243872
Tx Data Frames 12 Mbps (Mon) 155321
Tx Data Frames 24 Mbps (Mon) 57394
Tx Data Frames 36 Mbps (Mon) 48837
Tx Data Frames 54 Mbps (Mon) 580310
Tx Data Frames 72 Mbps (Mon) 721940
Tx Data Frames 108 Mbps (Mon) 2765549
Tx Data Frames 300 Mbps (Mon) 1959979
Tx Data Frames 450 Mbps (Mon) 0
Tx Data Frames 1300 Mbps (Mon) 0
Tx Data Frames 1300 Mbps+ (Mon) 0
Tx Data Bytes 12 Mbps (Mon) 16366781
Tx Data Bytes 24 Mbps (Mon) 55185933
Tx Data Bytes 36 Mbps (Mon) 50019354
Tx Data Bytes 54 Mbps (Mon) 655292622
Tx Data Bytes 72 Mbps (Mon) 698636377
Tx Data Bytes 108 Mbps (Mon) 2898214724
Tx Data Bytes 300 Mbps (Mon) 2101949376
Tx Data Bytes 450 Mbps (Mon) 0
Tx Data Bytes 1300 Mbps (Mon) 0
Tx Data Bytes 1300 Mbps+ (Mon) 0
Tx HT 6.5 Mbps 9707
Tx HT 13 Mbps 21356
Tx HT 19.5 Mbps 36035
Tx HT 26 Mbps 48837
Tx HT 39 Mbps 162048
Tx HT 52 Mbps 418254
Tx HT 58.5 Mbps 645171
Tx HT 65 Mbps 76758
Tx HT 72.2 Mbps 1385415
Tx HT 78 Mbps 546166
Tx HT 104 Mbps 833964
Tx HT 117 Mbps 750848
Tx HT 130 Mbps 64572
Tx HT 144.4 Mbps 1144574
Tx WMM [BK] 204214
Tx WMM [BE] 2169371
Tx WMM [VI] 193741
Tx WMM [VO] 243872
Tx WMM [BK] Dropped 1305
Tx WMM [BE] Dropped 7364
Tx WMM [VI] Dropped 1348
Tx WMM [VO] Dropped 569
Tx UAPSD OverflowDrop 0
TX Timeouts 0
Lost Carrier Events 0
Tx HT40 Hang Detected 0
Tx HT40 Hang Stuck 0
Tx HT40 Hang Possible 0
Tx HT40 Dfs IMM WAR 0
Tx HT40 Dfs HT20 WAR 0
Tx MAC/BB Hang Stuck 0
Tx Mgmt Bytes 339237031
Tx Beacons Bytes 4178907874
Tx Data Frames Dropped 37040
Tx AMSDU pkt count 520476
Tx EAPOL Frames Rcvd 573
Tx EAPOL Frames Dropped 3
Tx Data Frames MCS 0 : 10938
Tx Data Frames MCS 1 : 23607
Tx Data Frames MCS 2 : 56217
Tx Data Frames MCS 3 : 141685
Tx Data Frames MCS 4 : 688032
Tx Data Frames MCS 5 : 1156467
Tx Data Frames MCS 6 : 1396015
Tx Data Frames MCS 7 : 2671325
Tx Data Frames Legacy : 573
Tx Data Frames MCS : 6143713
Tx Data Frames NSS1 : 2684097
Tx Data Frames NSS2 : 3460189
Tx Data Frames GI(0.4) : 2529995
Tx Data Frames GI(0.8) : 3613718
Tx Data Frames BW 20 : 6144286
