Cloud Managed Networks
  • 1.  Radio won't enable
    Posted Feb 13, 2021 05:05 PM
    Hi, I have an Aruba IAP-207 In central and I'm trying to get my wlans working. I have everything configured including country code but under the AP status the radios say disabled even though they aren't and I'm not getting a SSID. The radio led is not on but I still was getting the set me up before I added to central. Is there anything I am missing? Thanks, Jack
    Jack Sommers
  • 2.  RE: Radio won't enable
    Posted Feb 13, 2021 05:17 PM
    You have to add the device to Central, assign it to a group and be sure that the country code is set.
    Rafael Del Cerro Flores
  • 3.  RE: Radio won't enable
    Posted Feb 13, 2021 05:26 PM
    I already did all of that
    Jack Sommers
  • 4.  RE: Radio won't enable
    Posted Feb 14, 2021 07:15 AM
    It sound like this Instant OS version were not enable for the country code you selected, could you try (as a test only) to change country code?
    You can check DRT files in order to go deep on that
    Regards
    Jorge Calvi
  • 5.  RE: Radio won't enable
    Posted Apr 13, 2021 11:38 AM
    You can configure 2.4 GHz and 5 GHz radio settings for an IAP either using Instant UI or CLI;
    1. Click the RF link at the top right corner of the Instant main window.
    2. Click Show advanced options. The advanced options are displayed.
    3. Click the Radio tab.
    4. Under the channel 2.4.GHz or 5GHz or both, configure the following parameters.
    Nich Fky
