Thank you for your reply. I made some progress.
I have created a policy from the NPS server with Service-Type = NAS Prompt. It allows me to log with radius into the switch but as you know no cli command works.
I know hot to create "a user group that permits all show commands"
but I don't know how to " return Aruba-Admin-role attribute with the local user group name"
Or
Return priv level using Aruba-Priv-Admin-User attribute
Let's say my is called oxidized, can you please give some syntax example on how to do that?
Again, thank you very much.
Adias
Original Message:
Sent: Feb 11, 2025 09:48 AM
Subject: Radius account with Operators level on ArubaOS-CX (6200F) switches
Create a user group that permits all show commands and return Aruba-Admin-role attribute with the local user group name.
You may also return priv level using Aruba-Priv-Admin-User attribute.
Command authorization is not possible with Radius. Check the following link:
https://arubanetworking.hpe.com/techdocs/AOS-CX/10.07/HTML/5200-7886/Content/Chp_Rem_AAA_RADIUS/use-rol-ass-usi-rad-att-10.htm
Original Message:
Sent: Feb 10, 2025 07:54 AM
I have RADIUS configured and work fine, but the current users have Administrators priviledge.
I need to create a new read/only RADIUS user to run Show .* (all) commands. I fail to find clear instructions in the documentation on how to do that chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://arubanetworking.hpe.com/techdocs/AOS-CX/10.13/PDF/security_6200-6300-6400.pdf
Can someone please work me through this process?
