  • 1.  Radius [ArubaOS Wireless - Terminate Session] failed
    Posted Aug 09, 2021 10:11 AM
    Edited by hysip Aug 09, 2021 10:11 AM
    Greetings,
    there might be a lot to consider on this kind of error like correct NAD &NAS I.P and Shared keys but already checked those multiple times and still get the same error.
    the objective is to automatically change the device role from quarantine to authenticated(vice versa) upon ongaurd agent scan(healthy or unhealthy).
    agent gets the correct posture but it seems the radius service don't trigger and the quarantine role retains.
    also upon checking:
    *#show ip radius source-interface
    Global radius client source IP address = 0.0.0.0, vlan 0(is it right to get this I.P?)
    *#show ip radius nas-ip
    RADIUS client NAS IP address = 10.x.x.x( the correct I.P of CPPM)
    also it seems I get no hits on 3799
    #show firewall-cp internal |include 3799
     *#show firewall-cp internal | include 3799
    ipv4 any 17 3799 3799 Permit 0 cpbwc-ipv4-radius-ldap
    ipv6 any 17 3799 3799 Permit 0 cpbwc-ipv6-radius-ldap
    i see no blocking so far on FW view.
    any suggestions ?
    TIA :)
    Harvey Ysip
  • 2.  RE: Radius [ArubaOS Wireless - Terminate Session] failed
    Posted Aug 09, 2021 10:27 AM
    What does the COA message in CPPM say? That should help us narrow down what could be happening.
    Brian Dempsey
  • 3.  RE: Radius [ArubaOS Wireless - Terminate Session] failed
    Posted Aug 09, 2021 06:38 PM
    Hi Brian,
    this adds up whenever onguard agent scans.
    Harvey Ysip
  • 4.  RE: Radius [ArubaOS Wireless - Terminate Session] failed
    Posted Aug 09, 2021 10:30 AM
    Edited by Craig Syme Aug 09, 2021 10:31 AM
    Did you configure the RFC3576 server on the controller?
    aaa rfc-3576-server "10.x.x.x"
    **EDIT**
    Here's a better link :)
    https://www.arubanetworks.com/techdocs/ClearPass/6.10/PolicyManager/Content/Deploy/Aruba%20Controller%20Configuration/RFC_server_configure.htm?Highlight=coa
    Craig Syme
  • 5.  RE: Radius [ArubaOS Wireless - Terminate Session] failed
    Posted Aug 10, 2021 07:18 AM
    The NAS-IP on your controller/IAP should be the IP of the controller/IP, not the CPPM. Unsure if I just mis-read it, or if you actually configured it with th CPPM IP. The CoA will go out to what is configured in the NAS-IP. Also note that if you have a Virtual IP on the ClearPass, the CoA will go out from the VIP, and the VIP should be configured as rfc3576/CoA server.
    What may help is to do a packet capture on the ClearPass (Collect Logs, enable packet capture), during that trigger a CoA and see if the CoA goes out and from/to which IPs; and if you see a reply from the controller/IAP.
  • 6.  RE: Radius [ArubaOS Wireless - Terminate Session] failed
    Posted Aug 11, 2021 12:29 AM
    Hi Herman,
    yes you are correct. changed it to controller-ip(Configuration>Authentication>Advance>RADIUS Client> NAS IPV4 and worked.
    thanks guys!
    Harvey Ysip
