  • 1.  RADIUS Authentication Issues
    Posted Oct 09, 2023 05:43 AM
    Hello Experts,
    Everyday with face with issue.
    In Mobility Master, put this number in each server:
    Timeout: 7
    Retransmits: 3
    Our Material:
    1- Mobility Master os version(8.6.0.9)
    2-Airwave
    3- Windows Server 2022 Datacenter Version 21H2
    Any help much be appreciated,
  • 2.  RE: RADIUS Authentication Issues
    Posted Oct 09, 2023 06:26 AM
    Edited by cjoseph Oct 09, 2023 06:59 AM
    EDIT:  Look at NPS radius server event viewer for clues.  Is the nps server across a wan?
  • 3.  RE: RADIUS Authentication Issues
    Posted Oct 09, 2023 06:46 AM
    Thanks for your comment.
    We have around 9 NSP servers.
    but my priority is first red box to solve.
    Best
  • 4.  RE: RADIUS Authentication Issues
    Posted Oct 09, 2023 06:49 AM
    Are your controllers pointing at a single NPS server or a load balancer?  Or do your controllers point at multiple servers?  Do you have load balancing enabled on the controller?
  • 5.  RE: RADIUS Authentication Issues
    Posted Oct 09, 2023 06:58 AM
    Thanks for your rapid respond.
    Are your controllers pointing at a single NPS server or a load balancer? No, multi servers,
    Do you have load balancing enabled on the controller? Yes,  Classic Controller Cluster is enabled. 2 controller manage by mobility master.
  • 6.  RE: RADIUS Authentication Issues
    Posted Oct 09, 2023 07:02 AM
    I would limit the number of servers configured on your Aruba Controllers to narrow down the issue.  If the problem happens on all the servers, it has to be path between the servers and the controller(s).
  • 7.  RE: RADIUS Authentication Issues
    Posted Oct 09, 2023 07:19 AM
    I have checked the path and no issue. is there any relationship between these issues and Microsoft Windows? Should I update al servers?
    I've put also MTU size policy in servers( Framed-MTU:1344).
  • 8.  RE: RADIUS Authentication Issues
    Posted Oct 09, 2023 09:30 AM
    I would start by opening a technical support case.  There are a great deal of ways that this issue could be caused and someone needs to look at your logs and get to the bottom of it.  It would  happen more quickly with a technical support case than if I answer and guess at your issue here.
