Skip main navigation (Press Enter).
Log in
Toggle navigation
Search Options
Log in
Home
Discussion Forum
Support
Documentation Portal
Support Knowledge Base
HPE Networking Support Portal
HPE Aruba Networking Central Status
Live + Virtual Events
Webinar Archive
Upcoming Events
News
Technical Blog
ACEX Hall of Fame
MVP Program
Become a Member
Search Options
Community Home
Discussion
123K
Members
3.4K
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
Radius Certificate Issue
joe3523
Apr 16, 2008 01:29 PM
Hello, I have installed an HP 5304xl with the WIFI module and am having issues authenticating with my ...
Mohieddin Kharnoub
Apr 21, 2008 09:12 AM
Hi Check the WLAN config on the WESM and Compare it with your one on the Windows machine. Little description ...
1.
0
Kudos
joe3523
Posted Apr 16, 2008 01:29 PM
Reply Privately
Options Dropdown
I have installed an HP 5304xl with the WIFI module and am having issues authenticating with my Radius server, IAS. I get a "Windows was unable to find a certificate to log you on to the WIFI Network".
Any ideas?
Thanks for the help!
2.
RE: Radius Certificate Issue
0
Kudos
Mohieddin Kharnoub
Posted Apr 21, 2008 09:12 AM
Reply Privately
Options Dropdown
Hi
Little description of your scenario with some config. will be helpful.
Good Luck !!!
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Related Content
WESM Local Radius Authentication Failure
TMS Admin
Added Aug 10, 2008
Discussion Thread
3
Management Authentication using Windows NPS
RWN
Added Dec 31, 2015
Discussion Thread
3
Machine authentication for windows
victorlwt
Added Oct 03, 2014
Discussion Thread
7
RADIUS Authentication
RR8
Added Apr 04, 2012
Discussion Thread
13
RWN
Added Dec 31, 2015
Library Entry
Copyright 2024. All rights reserved.
Powered by Higher Logic
