Skip main navigation (Press Enter).
Log in
Toggle navigation
Log in
Home
Discussion Forum
Support
Documentation Portal
Support Knowledge Base
HPE Networking Support Portal
HPE Aruba Networking Central Status
Live + Virtual Events
Webinar Archive
Upcoming Events
News
Technical Blog
ACEX Hall of Fame
MVP Program
Become a Member
Community Home
Discussion
124K
Members
3.7K
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
Radius Certificate Issue
joe3523
Apr 16, 2008 01:29 PM
Hello, I have installed an HP 5304xl with the WIFI module and am having issues authenticating with my ...
Mohieddin Kharnoub
Apr 21, 2008 09:12 AM
Hi Check the WLAN config on the WESM and Compare it with your one on the Windows machine. Little description ...
1.
Kudos
joe3523
Posted Apr 16, 2008 01:29 PM
Reply Privately
Options Dropdown
I have installed an HP 5304xl with the WIFI module and am having issues authenticating with my Radius server, IAS. I get a "Windows was unable to find a certificate to log you on to the WIFI Network".
Any ideas?
Thanks for the help!
2.
RE: Radius Certificate Issue
Kudos
Mohieddin Kharnoub
Posted Apr 21, 2008 09:12 AM
Reply Privately
Options Dropdown
Hi
Little description of your scenario with some config. will be helpful.
Good Luck !!!
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Related Content
WESM Local Radius Authentication Failure
TMS Admin
Added Aug 10, 2008
Discussion Thread
3
Management Authentication using Windows NPS
RWN
Added Dec 31, 2015
Discussion Thread
3
Machine authentication for windows
victorlwt
Added Oct 03, 2014
Discussion Thread
7
RADIUS Authentication
RR8
Added Apr 04, 2012
Discussion Thread
13
RWN
Added Dec 31, 2015
Library Entry
Copyright 2024. All rights reserved.
Powered by Higher Logic
