  • 1.  RADIUS Message-Authenticator
    Posted Jul 31, 2024 08:07 AM
    my question is in regards to the security advisory regarding the latest RADIUS vulnerability, HPESBNW04675 (I can't link it here for some reason)
    We want to make the two recommended changed to Clearpass:
    Require Message-Authenticator from NAD = yes
    Require Message-Authenticator from Proxy Server = yes
    I do not know what changes, if any, i would need to make on the wireless controller to not break RADIUS Authentication.
    We use RADIUS for admin authentication, for 802.1x and for MAC Authentication.
    We are running Controllers on Version 8.11, with a conductor, Clearpass is on 6.12.2
  • 2.  RE: RADIUS Message-Authenticator
    Posted Jul 31, 2024 12:36 PM
    Have you looked at the security advisory on this same subject that was previously released and covers the network devices?
    https://networkingsupport.hpe.com/notifications/Tm90aWZpY2F0aW9uOjE5ODEw;notificationCategory=Security
    Carson Hulcher, ACEX#110
  • 3.  RE: RADIUS Message-Authenticator
    Posted Aug 01, 2024 03:12 AM
    Yes, i looked into the other advisories as well. But since the fixed AOS 8.12.0.2 is not released yet, i'm not sure how they can apply.
    And the only configuration that is described in that document is also just the Clearpass setting "Require Message-Authenticator from NAD = yes"
  • 4.  RE: RADIUS Message-Authenticator
    Posted Aug 06, 2024 05:03 PM
    The message-authenticator is a value that may (or may not) be present in RADIUS requests and responses. The presence of message-authenticators is required to protect against the BlastRADIUS weaknesses; with those new settings in ClearPass, any RADIUS packets that do not contain a message-authenticator will be dropped silently.
    So in order to activate these settings, you have to make sure that all of your NADs (switches, controllers…) include message-authenticators in their requests, otherwise the activation will break your authentication.
    For 802.1x, message-authenticators have always been mandatory, so PAP/CHAP/MAC-Auth requests have to be checked.
  • 5.  RE: RADIUS Message-Authenticator
    Posted Aug 07, 2024 02:54 AM
    My question boils down to: How do i check for the presence of the Message-Authenticator on the wireless controller?
    We were able to perform a partial test yesterday and enabled the two service parameters on a test system. Administrative logons to a test controller worked without a hitch, but the clearpass change broke our wired switches in the test environment (a totally different topic handled by a different internal team), so we rolled back before i had time to also test wireless authentication.
    At least it is good to have a confirmation that 802.1x is not affected, but we also do a lot of MAC-Auth via RADIUS, and i have not seen anything obvious that i would need to change in the MAC-Auth profiles.
    My next internal test window will be at the end of the week, i will report back :D
  • 6.  RE: RADIUS Message-Authenticator
    Posted Aug 07, 2024 04:36 AM
    If you have separated your RADIUS traffic from networks that your users have access to, the vulnerabilities mentioned in Blast-RADIUS are not exploitable. These require a man-in-the-middle between your switches/APs and your RADIUS server. As RADIUS is mostly unencrypted, that would be recommended anyway, so if (malicious) users have the possibility to sit in between your switches/APs and your RADIUS server, you may have other things to worry about. Moving to RadSec, or VPN technology to protect your RADIUS traffic eliminates the risk of this vulnerability, and others (like unencrypted data). The reason for the high score on the vulnerability is because some users run RADIUS (unencrypted) over the internet.
    As well, mentioned before, if you have any EAP method (EAP-TLS/TEAP/PEAP), there are Message Authenticators included already, so there is no risk. As you mentioned for PAP/MAC Auth, the risk is there, but only if you allow man-in-the-middle on your RADIUS traffic.
    Having said that, in the bulletin posted on the Networking Support Portal, you can check which versions of software you need. With those versions, the Message Authenticators should be there.
  • 7.  RE: RADIUS Message-Authenticator
    Posted Aug 07, 2024 04:49 AM
    The RADIUS traffic is isolated, but nonetheless, our Security Teams sees a CVE 9.0 and tells us we need to make the change on clearpass, because our Insurance requires us to properly mitigate any security issues.
    But if you say that the update to 8.12.0.2 will add the message-authenticator to all RADIUS requests, that is exactly the information i need, since i am already in the process of deploying that upgrade.
  • 8.  RE: RADIUS Message-Authenticator
    Posted Mar 14, 2025 04:53 AM
    hello, as Herman esplain, I understand that there is not a feature for enable message-authenticator in the NAD devices, it is a "native feature" of the protocol used, eap.tls have the message authenticatir andh mac-authentication not, it is right?, there is not possibility to enable the message authernticator in the mac authentication packets configuring the Wireless controller or the switch that act as radius client?
    ACMP ACSP ACCP ACEP ACDP
  • 9.  RE: RADIUS Message-Authenticator
    Posted Aug 07, 2024 05:02 AM
    To check for the presence of Message-Authenticators, I suggest to do a packet capture from within ClearPass. - Under 'Server Configuration', select a server and click on 'Collect Logs':
    In Wireshark, you can then examine the RADIUS packets contained in the capture file. You'd be looking out for a Message-Authenticator type of attribute within the request:
  • 10.  RE: RADIUS Message-Authenticator
    Posted Aug 13, 2024 03:08 AM
    That is usefull information, i was not aware you could to pcap traces on the clearpass server.
    But luckily i don't need that anymore. Over the weekend i updated the wireless to 8.12.0.2, and yesterday i set the service parameters on a clearpass test server.
    Everything works: EAP-TLS obviously, but also MAC Authentication works, and admin login to the controllers works as well. Everything without configuration changes on the controllers.
    Now only RADIUS admin login to our switches (Comware, AOS-S, AOS-CX) doesn't work anymore. That gets the "Missing message Authenticator" message in the clearpass eventlog. But i think switching that to TACACS might be the simplest solution.
