RAP-155 with 3G/4G Uplink (Huawei E3276S-1) only works in Germany?
  • 1.  RAP-155 with 3G/4G Uplink (Huawei E3276S-1) only works in Germany?
    Posted May 29, 2015 09:50 AM
    I'm putting together a lab test for a customer. I'm using a Huawei E3276 USB modem (from the Supported List), which after upgrading to InstantOS 4.1.1.6 is detected correctly by the RAP. However, in the Uplink configuration, the only country available in the drop-down list is Germany, with two networks available. I am using an O2-UK SIM card which I have tested successfully with the same USB modem and my laptop.
    Has anybody had any luck with this model of modem?
    FYI, 'AP 3G/4G Status' shows the following:
    cellular status
    card     detect     link
    Present  detect-ok  Linkdown
    USB Modem Information
    Parameter      Value
    Manufacturer    HUAWEI
    Product         HUAWEI Mobile
    Serial Number
    Driver          option
    Vendor ID       12d1
    Product ID      1001
  • 2.  RE: RAP-155 with 3G/4G Uplink (Huawei E3276S-1) only works in Germany?
    Posted May 31, 2015 12:48 AM
    I advice you to open a TAC ticket to understand more about this.
  • 3.  RE: RAP-155 with 3G/4G Uplink (Huawei E3276S-1) only works in Germany?
    Posted May 31, 2015 05:57 AM
    I've been speaking to TAC as well. Not got anywhere so far but will update the thread if we find the answer. Thanks :)
  • 4.  RE: RAP-155 with 3G/4G Uplink (Huawei E3276S-1) only works in Germany?
    Posted May 31, 2015 09:23 AM
    Sure.
    let you know If I find some solution for this.
