  • 1.  RAP 2WG Speed Problem
    Posted Mar 05, 2013 09:01 AM
    Hi All
     I got the RAP 2WG  and only speed 500KB with wire port and 1500KB on wireless.
    I saw some one the the same problem on here
    http://community.arubanetworks.com/t5/Remote-Networking/Remote-AP-Speeds/td-p/8026
    but no solution for that.
    Any one can help?
  • 2.  RE: RAP 2WG Speed Problem
    Posted Mar 05, 2013 11:24 PM
    The RAP2WG does not have great performance.  Please consider enabling BCMC optimization on the user VLANs for the wired and wireless VLANs on the RAP2WG to improve performance.
  • 3.  RE: RAP 2WG Speed Problem
    Posted Mar 06, 2013 12:58 AM
    Hi cjoseph
    thanks for your reply, i know 2WG's performacne is not so good.
    but my question is how come the same 2WG and same notebook, but the speed of wire port is less than wirless conection in same vlan?  Wire port got 500KB and Wireless Port got 1500KB.
  • 4.  RE: RAP 2WG Speed Problem
    Posted Mar 06, 2013 05:22 AM
    There are a number of reasons why this could happen.  If you open a case with support, they can run down the list of reasons why by getting information from your controller, access point and internet connection.
