All controllers in the cluster would need a public ip address.
You would need to configure the rap-public-ip address for each controller in the cluster profile
Do not define an LMS or backup LMS-IP in the ap-group for the Remote AP.
HPE Design and Deploy Guides:
https://community.arubanetworks.com/support/migrated-knowledge-base?attachments=&communitykey=dcc83c62-1a3a-4dd8-94dc-92968ea6fff1&pageindex=0&pagesize=12&search=&sort=most_recent&viewtype=card------------------------------
Original Message:
Sent: Jul 07, 2022 08:38 PM
Subject: RAP 303HR disconnecting
Yes, the 2 controllers are in a cluster.
Kind Regards,
Peter Abene | Wireless LAN Network Engineer
o +1 732-812-8339 • m +1 973-975-7961 peter.abene@vonage.com
23 Main St. • Holmdel, NJ 07733 • USA
Original Message:
Sent: 7/7/2022 6:42:00 PM
Subject: RE: RAP 303HR disconnecting
Is it a cluster?
Original Message:
Sent: Jul 07, 2022 10:47 AM
Moving RAPS to an 8.6 infrastructure (from old 6.5 master controller). RAP joins the controller but then disconnects pretty fast. The only thing I can see is that the "vrrp-vlan" ip address for the cluster members is not correct. Would that cause RAP to drop? If not, why does it drop?
