  • 1.  RAP or IAP with VPN to MC?
    Posted Apr 08, 2019 07:00 PM
    Hi gurus,
    About this picture:
    I am clear and understand the Branch Office Controller and VIA solutions. But, what is the difference between to have a RAP or an IAP cluster with a VPN connection to an MC? If the branch office needs corporate access, which option is better, RAP or IAP VPN? I have worked with RAPs, but I haven't with IAP VPN. Is the IAP VPN solution deployed widely or quite the opposite? I suppose this is a open question, but I would like someone to shed some light on this for me.
    Julián
  • 2.  RE: RAP or IAP with VPN to MC?
    Posted Apr 08, 2019 10:18 PM
    RAPs
    * are managed by the controller
    * requires a controller license
    * but not a good solution if you require more than one and roaming is needed between the Aps
    * good for extending L2 VLANs
    * can be configured in full or split tunnel mode
    IAP
    * can be managed locally or via AirWave
    * doesn’t require a controller license
    * the controller only serves as VPN concentrator
    * good solution if you require more than one and roaming is needed between the Aps
    * more flexible (distributed design approach) : L2 Distributed , L2 Centralized , L3 Centralized , L3 Distributed
    https://www.arubanetworks.com/techdocs/Instant_41_Mobile/Advanced/Content/UG_files/IAP_VPN/IAP_VPN_Conf.htm
    Sent from Mail for Windows 10
  • 3.  RE: RAP or IAP with VPN to MC?
    Posted Apr 09, 2019 09:57 AM
    Nice explanation, thank you!
    Julián
  • 4.  RE: RAP or IAP with VPN to MC?
    Posted Oct 29, 2019 11:52 AM
    Hi Victor
    Precise and clear explaination.
    Rgds
    Sabri
