  • 1.  RAP over Mesh queery
    Posted Jun 09, 2016 10:05 AM
    Hi all, I have a simple IAP134 Mesh point/portal, im going to convert to controller based.  At the point end can I have 105's configured as RAP's , for access back to the controller ? Any reason why not ??
  • 2.  RE: RAP over Mesh queery
    Posted Jun 09, 2016 10:40 AM
    An AP-105 over an IAP 134/135 mesh? It should be fine so long as the 105 knows how to find the controller.
  • 3.  RE: RAP over Mesh queery
    Posted Jun 10, 2016 07:12 AM
    Cheers Jerod, yes I guessed as much, they are alredy configured as RAP's but intermittently drop off the network, Mesh seems ok but not sure what sort of latency/dropout would mean Raps would reboot ??
  • 4.  RE: RAP over Mesh queery
    Posted Jun 11, 2016 09:50 PM
    Hi, could you please tell me what is the reboot or bootstrap info you see from ap debug system-status output?
  • 5.  RE: RAP over Mesh queery
    Posted Jun 11, 2016 10:50 PM
    You may also want to set the IAPs to a static channel and power and disable ARM to see if maybe you are hitting some channel changes that are dropping the RAP link.
