  • 1.  RAP Provisioning
    Posted May 16, 2013 04:57 PM
    I pre-provisioned a RAP2 device and I want to see the IP address parameters I setup on it when I provisioned it.  The Rap is not currently online but I want to see what I saved when I provisioned it.  How can I do that from the CLI?
    Thanks, Tony
  • 2.  RE: RAP Provisioning
    Posted May 16, 2013 05:01 PM
    You can do show ap database | include <name of the rap> and it should show up on the down list with the ip address it was setup if it came up or you can do show audit-trail and you can see the changes you made
  • 3.  RE: RAP Provisioning
    Posted May 16, 2013 05:06 PM
    Well, I did not get any returned data on the first command but the ah audit-trail did the trick.
    Thank you kindly.
