RAP5 4G UML290
  • 1.  RAP5 4G UML290
    Posted Apr 06, 2012 03:15 PM
    I have a working RAP that I'm trying to go from dsl wired connection to a verizon 4G UML290VW-G wireless modem.
    When I go to RAP provisioning screen and select USB tab the UML290 isn't listed.  I've tried using the UM175 / UM150 (Verizon) that is listed but it's still not working.
    The RAP is on ArubaOS Verison 5.0.4.0 Build #29678 and the 3600 Controller is on 6.1.2.6 software.
    #3600
  • 2.  RE: RAP5 4G UML290
    Posted Apr 06, 2012 03:20 PM
    Not sure it makes a difference but the RAP i'm using is a RAP5WN
  • 3.  RE: RAP5 4G UML290
    Posted Apr 06, 2012 03:33 PM
    That modem has not been added to the Zero touch provisioning screen of the RAP5.  You can only provision it from the controller using ArubaOS 6.3.0 or higher.
  • 4.  RE: RAP5 4G UML290
    Posted Apr 06, 2012 03:38 PM
    Once I get the controller to the 6.1.3.1 software how do I go about provisioning it via the controller?  Is that in the 6.1 manual somewhere?
    Thanks for the quick reply.  YOU ROCK !!!
  • 5.  RE: RAP5 4G UML290
    Posted Apr 06, 2012 03:43 PM
    First. use the Verizon VZaccess Manager on a Windows laptop to make sure the firmware on the Pantech is the newest.  Next, provision the RAP so that terminates on the controller.  When it does, provision the AP from the controller with the following options:
  • 6.  RE: RAP5 4G UML290
    Posted Apr 10, 2012 12:59 PM
    That worked great.
    Thanks again !!!
  • 7.  RE: RAP5 4G UML290
    Posted Apr 18, 2012 09:10 PM
    I've got a UML290 too.  But I've never configured a RAP5 to use a usb device.  TAC sent me a document on how to configure a 3g device and it looks like they require a device identifier and a device type.  I can't find anything about whether the 290 needs it or not.  Do you guys have any info?
    Thanks in advance
    Jimmy
  • 8.  RE: RAP5 4G UML290
    Posted Apr 18, 2012 09:13 PM
    You cannot Zero Touch configure a UML290.  You need it to connect to the controller wired, and then reprovision it with the instructions above.
  • 9.  RE: RAP5 4G UML290
    Posted Apr 18, 2012 09:23 PM
    Thanks for the quick response!  So I only need to modify the three boxes you highlighted in red?  I'll try that and get back with you.
  • 10.  RE: RAP5 4G UML290
    Posted Apr 18, 2012 09:24 PM
    Yes.  Make sure they have those values.
  • 11.  RE: RAP5 4G UML290
    Posted Apr 18, 2012 10:11 PM
    Wow.  That was way too easy.  I believe I was over thinking it.  Thanks so much for the help.
    Jimmy
  • 12.  RE: RAP5 4G UML290
    Posted Aug 21, 2012 11:12 AM
    Colin, I'm trying to get a RAP5 going with a Verizon USB551L 4g modem.  It appears this is manufactured by Novatel Wireless.  Would the USB settings be different when provisioning the RAP from the controller?
    Matt
  • 13.  RE: RAP5 4G UML290
    Posted Mar 19, 2013 05:45 PM
    Were you ever able to get the USB551L working on the RAP5?  If so, can you share your settings.  I have a RAP3 I am trying to setup.
    Sam
