So I had a RAP5 up and working fine, provisioned from our master which at the time was a 6000.
Last night I demoted the 6000 to be a local controller and promoted our 3600 to be the master. Everything seemed fine with our APs, but since then my RAP5 is stuck in a constant upgrade-reboot-upgrade loop.
SInce it was having problems I held down the reset on the RAP and let it reboot to defaults. It came up with the crazy old 3.x software load. I give it the IP of the new master controller. It connects fine, says it has to upgrade and then reboots. After that it come up in the new 6.x WebUI, and the connectivity tabs reads
Retrieving IP info... check
Initializing TPM certs ... check
establishing connection to master IP ... check
Upgrading Image. This process may take a few minutes. Please be patient... spinny wheel
the it will reboot and cycle through that again and again
I checked on the master and I do see my external IP coming in on port 4500 with a 'show datapath session table'
so I know connectivity is good. That and it worked fine until the promotion/demotion so nothing should have changed access wise.
The RAP5s MAC is in the RAP whitelist for both the master and the local controller.
If I look in the syslog I see
Jan 11 13:08:50 a6000-0.blah.EDU authmgr[1808]: <522038> <INFO> <a6000-0 x.x.x.18> username=00:0b:86:66:a0:79 MAC=00:00:00:00:00:00 IP=y.y.y.y Authentication result=Authentication Successful method=VPN server=Internal
Jan 11 13:08:50 a6000-0.blah.EDU authmgr[1808]: <522008> <NOTI> <a6000-0 x.x.x.18> User Authentication Successful: username=00:0b:86:66:a0:79 MAC=00:00:00:00:00:00 IP=10.10.10.14 role=ap-role VLAN=1 AP=N/A SSID=N/A AAA profile=default auth method=VPN auth server=N/A
If I let the RAP5 sit, it will iterate through all the IPs in my RAP-pool (10.10.10.10 -> 20) and on the 11th time hang and not reboot. Until then it will cycle like that.
Anyone seen a RAP cycle like this, or know what my next step should be. I feel like its probably something simple I've missed, but comparing configs between the two controllers I'm not seeing it.
Jeff
#3600
